Detailed Status Messages - Logon, Logoff, and Shutdown
Enable or Disable Detailed Verbose Logon, Logoff, Startup, and Shutdown Status Messages in Vista and Windows 7
This will allow you to enable or disable displaying status messages that reflect each step in the process of starting, shutting down, logging on, or logging off the computer.This is disabled by default in Vista and Windows 7.
If enabled, you will get more detailed (verbose) status messages than just the normal "Logging On", "Logging Off", or "Shutting Down" messages.
EXAMPLE: Shutdown with one Detailed Status Message step
OPTION ONE
2. In the left pane, click on Computer Configuration, Administrative Templates, and System (See screenshot below)​
3. In the right pane, right click on Verbose vs normal status messages and click on Properties. (See screenshot above)​
4. To Enable Detailed Status Messages
B) Go to step 6.​
5. To Disable Detailed Status Messages
OPTION TWO
Using a REG File Download
1. To Enable Detailed Status Messages
Enable_Detailed_Status_Messages.reg
download
B) Go to step 3.​
2. To Disable Detailed Status Messages
Disable_Detailed_Status_Messages.reg
download
7. Log off, shut down, or log on to see the changes.​
OPTION THREE
Manually in Registry Editor
NOTE: This option will work for all Vista editions.
1. Open the Start Menu.​
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System
A) In the right pane, right click on a empty area and click on New and DWORD (32-bit) Value. (See screenshot below)​
B) Type VerboseStatus and press Enter.​
C) Right click on VerboseStatus and click on Modify.​
F) Go to step 7.​
6. To Enable Detailed Status Messages
A) In the right pane, right click on VerboseStatus and click on Delete. (See screenshot above)​
7. Close regedit.​
8. Log off, shut down, or log on to see the changes.​
That's it's,
  • Disable_Detailed_Status_Messages.reg
  • Enable_Detailed_Status_Messages.reg
