Event Viewer - Fix ERROR ID 10
  1. #1
    <!-- google_ad_section_start -->Event Viewer - Fix ERROR ID 10<!-- google_ad_section_end -->
    How to Fix the ERROR ID 10 in Vista Event Viewer
    Published by Ashvin Busviah is offline
    21 Jul 2010
    Event filter with query "SELECT * FROM_InstanceModificationEvent WITHIN 60 WHERE TargetInstance ISA "Win32_processor" AND TargetInstance. Load Percentage >99 could not be reactivated in namespace"// ./root/CIMV2" because of error 0x80041003. Events cannot be delivered through this filter unitl the problem is corrected
    For vista 32 bit
    ok Think I got the fix..
    1. start> run > cmd
    2. type in
    • net stop winmgmt
    • Select (Y)
    • DEL C:\Windows\System32\wbem\Repository\*.*
    • Select (Y)
    3. Restart the system you will see some wmi errors still in the event log but not the ERROR ID10
    4. Restart the computer again.. to get rid of the errors..
    cheers
    Published by
    Ashvin Busviah's Avatar
    Senior Member
    Array
    Tutorial Tools
    Applies to
    All Vista Versions
    32 Bit
  2. #1
    Newbie
    Microsoft Windows Vista Home Premium 32bit
    Local Time: 02:20 AM
    Re: Event Viewer - Fix ERROR ID 10
    I have this same problem and I did what was said to fix it. The only problem is that when I did it. CMD stopped the following:
    Security Service
    Pure Network Platform
    Windows Management Instrumention
    Internet Control Sharing
    IP Helper
    I don't know what to do now, according to the fix, I don't think that was supposed to happen...
    Please Help!!
Event Viewer - Fix ERROR ID 10 problems?
Tutorial Tutorial Starter Category Comments Last Post
Error in Event Viewer Matt27LFC General Discussion 21 15 Jan 2009
Event Viewer Error Julian Vista General 1 07 Mar 2008
Vista Event Viewer error ID 100 Safai Vista General 0 17 Sep 2007
Vista Event Viewer error ID 100 Safai Vista performance & maintenance 0 17 Sep 2007
Event viewer error Kent Wilson Vista performance & maintenance 2 22 Dec 2006
