Wireless Keys Stored In Windows - View
How to See the Wireless Keys that Windows has Stored
The BBCODE in this needs a lot of fixing, but I wanted to submit it then work on it at a later date. The screenshots are also wrong for the x64 option - I'll fix those later
Some AVs are detecting this as malicious - this is because it's trying to access saved passwords. You may have to allow this file in your AV in order to use this.
When you join a protected wireless network, Windows will store the key to allow a connection to be automatically made next time you log on to the computer.
This information is stored in an encrypted format in the following locations:
XP: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WZCSVC\Parameters\Interfaces\[Interface Guid]
Vista: C:\ProgramData\Microsoft\Wlansvc\Profiles\Interfaces\[Interface Guid]
Windows 7: C:\ProgramData\Microsoft\Wlansvc\Profiles\Interfaces\[Interface Guid]
Because it's encrypted, we'll need a program to open it up for us :) We will be using a tool from Nirsoft called WirelessKeyView.
There are different instructions for x86 (32 bit) and x64 (64 bit) computers
For x86 (32 bit) Computers
1. Please download WirelessKeyView from this site and save it to your desktop:
Direct Download Link: WirelessKeyView Download
2. Minimize all windows to get to your desktop, and right click on the file, then select Extract All...
3. When the dialogue box opens, make sure that the box Show Extracted Files When Complete is selected. Then press Extract.
4. When the folder opens, double click on the file WirelessKeyView.exe
5. When WirelessKeyView opens, you should have the following screen. All the information about the wireless keys is given below :) The ASCII code is what you want.
For x64 (64 bit) Computers
Direct Download Link: WirelessKeyView x64 Download
Enjoy!
Tom
Great info Tom, i put this on my Speed Dial to use if needed in answering any post requiring it.
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
Thanks Bill :) I'm glad you liked it. I'll finish it off tomorrow
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    Samsung EVO 128GB SSD
    Seagate Barracuda 2TB 7200rpm
    NZXT Phantom 410
Thanks Tom, Great information, Now it resides in my favorites, and deserves a tip if the scales.
Patch41.
I'm glad you found it useful :) Thanks for the rep!
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Hi Tom, just like the instructions say some security programs see it as a trojan, So if any of the guy's would like to use it, Suspend the security program for a hour get the information, then turn back on, malwarebytes picked it up as virus, and norton cleaned it out completly, Patch41,
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
