| Administrator | Hard drive speed boosts |
| Administrator | Re: Hard drive speed boosts Nothing really to check in them other than to turn them off so that they are not running in the background causing the hard drive to run a lot. Index - Enable or Disable Disk Defragmenter You can also look in the Resource Monitor under the Disk section to see what is running that is using up the HDD disk. |
| Banned | Re: Hard drive speed boosts From the resource monitor at a certain point it's hard to tell because the background operations are changing back and forth. I used the Auslogics defrag program and it stated that my PC is not optimized although the elaboration wasn't provided. After a period of the time the programs in the background disappear and it does seem to run smoothly but whatever I may engage their seems to be some sort of hesitation from the hard drive and that's what I don't understand. I've never witnessed this before on a 500GB and Vista absolutely operated smoothly regardless of the performance tweaks. Do you think it's got something to do now with the firmware? |
| Administrator | Re: Hard drive speed boosts You might see if clearing the temp files may help any. Otherwise I'm not certain what is causing this hesitation either. Temporary Files - Temp Folder |
| Member | Re: Hard drive speed boosts Whenenabling advanced performance for hard drive and a poer outage happens, will this just randomly loss or corrupt files on your hard drive or files that are open when it happens? |
| Administrator | Re: Hard drive speed boosts Hello Shortmantuff, Only if it was in the middle of being saved to the hard drive, otherwise you would just loose whatever that was in the cache. It's usually not a problem though unless you have a lot of power outages though. |
| Member | Re: Hard drive speed boosts Never knew about this, thanks! |
| Administrator | Re: Hard drive speed boosts You're welcome Microdude. |
| Nada y nada | Re: Hard drive speed boosts Thank you Brink. I didn't come across either setting when I was speeding up my hard drive the first time around. The new release of Auslogics Disk Defrag is impressive. But I do worry if the increased speed is at the cost of effectiveness. |
| Member | Re: Hard drive speed boosts Ditto. It's insanely fast, but hope it doesn't effect it. |
| Tutorial Tools | |
| Tutorial | Category | |||
| Hard drive light constantly flashing ,reading hard drive during id | Vista hardware & devices | |||
| Crashed hard drive...copied hard drive but can't access User area | Vista General | |||
| SATA & eSATA hard drive speed poor | Vista hardware & devices | |||
| very slow hard drive write speed | Vista hardware & devices | |||
| Transferring files from Slave XP hard drive to new Vista Hard drive - primary | Vista installation & setup | |||
