Vista - Hard drive speed boosts
Comment
Old 04-28-2007
Brink
How to Increase Hard Drive Performance in Vista
Old 04-07-2008
Harkin
Vista Home Premium 64bit
Re: Hard drive speed boosts
I hope we aren't confusing the Motherboard chipset drivers with the Raid drivers?
Old 04-07-2008
amplid
Vista Ultimate x64
Hey guys, one question, what is RAID??
Amplid
Old 04-07-2008
z3r010
Quote  Quote: Originally Posted by amplid View Post
Amplid
RAID - Wikipedia, the free encyclopedia
Old 04-07-2008
amplid
Vista Ultimate x64
Haha thanks z3r010
Amplid
Old 04-15-2008
channelv
Vista Ultimate x64
If the checkbox doesn't stay checked, then it is most likely one of two things:
1. You are using the Intel Matrix drivers, which is fine - it enables advanced performance, such as this, and NCQ by default, so it won't let you check the box
2. You have Intel Turbo Memory - the drivers include the Intel Matrix driver, thus advanced performance is already enabled as well and the checkbox mentioned here doesn't do anything.
Either case, don't worry - the hard drive has all advanced features enabled with these drivers already.
Old 05-15-2008
SCSIraidGURU
Vista x64 Ultimate
SCSI and SCSI RAID controllers using non-Microsoft manufacturer drivers don't have this problem. Microsoft only disabled write caching in its drivers. I use SCSI, SCSI RAID, and SAS RAID controller with the manufacturer drivers. You can check them with dskcache utility.
Old 07-10-2008
PainlessTorture
Windows Vista™ Ultimate x64
If i enable advanced performance and my power goes off, will i lose everything?
Old 07-10-2008
Brink
Hi Fmjc001,
You would only lose what was currently in the cache files of your hard drive that has not been written to the hard drive yet. This would only be what you were currently doing when you lost power. You would not lose everything on the hard drive.
Old 07-10-2008
PainlessTorture
Quote  Quote: Originally Posted by Brink View Post
Hi Fmjc001,
Ok thanks, Another great tut!
Old 07-10-2008
Brink
Your welcome Fmjc001.
Comment
Tutorial Tools
Tutorial Category
Hard drive light constantly flashing ,reading hard drive during id Vista hardware & devices
Crashed hard drive...copied hard drive but can't access User area Vista General
SATA & eSATA hard drive speed poor Vista hardware & devices
very slow hard drive write speed Vista hardware & devices
Transferring files from Slave XP hard drive to new Vista Hard drive - primary Vista installation & setup
