Vista - Hard drive speed boosts
Comment
Old 04-28-2007
Brink
How to Increase Hard Drive Performance in Vista
Old 12-16-2008
TMM
Vista Business 32bit
Re: Hard drive speed boosts
I have RAID 0 configration and when I enable these settings and go back to check them I see they are reverted back to their default values. How can I solve the issue? Thanks
Old 12-16-2008
SCSIraidGURU
Vista x64 Ultimate
On RAID, they don't always work. I would be very careful with RAID 0. If it fails, you lose everything.
Old 12-16-2008
Brink
Hi TMM,
I would not recommend trying to do this on a RAID setup either.
Old 12-17-2008
s99
Vista Ultimate x64
Thanks for this tut!! btw i'm on a lappy so i can safely enable HDD advanced performance since risk of power loss is minimal(battery!) !!
btw merry xmas !!
Old 12-17-2008
SCSIraidGURU
Vista x64 Ultimate
It is not always safe. If you OS is stable and not prone to lockups and forced reboot, try it. If you have any issues, don't. Data could be lost and your OS may crash due to errors writing to the registry from the cache. The battery they mean is a battery backup cache on your controller. It protects your data in the cache.
Old 12-17-2008
Brink
You're welcome s99.
It's your call, but it should be ok if you do not let it run out of power.
Old 12-19-2008
totalz
Vista Ultimate x64
Is it safe to "Enable advanced performance"? As it is only recommended for disks with a backup power supply. Does it actually increase the file system cache size? Where can I find the current setting for file system cache size?
thanks.
Old 12-20-2008
Brink
Hello Totalz,
That was not a recommendaton in this tutorial, but it is a good idea if you have power failures.
It is usually safe to do unless you are always losing power for whatever reason. It is not recommended for external drives that you unplug from the computer.
The cache that it uses cannot be manually adjusted. It is comppletely handled by Vista.
Old 12-20-2008
PainlessTorture
Windows Vista™ Ultimate x64
You could just get a surge protector. There is one that keeps your computer going for about 3 Min's. Just set your computer to shutdown on switch to battery power. I dont know if this would work, but I dont see why it wont.
Old 12-28-2008
PainlessTorture
Hmm, when I check the box saying write cache and advanced performance and then click OK it just goes back to unchecked. If there some sort of lock on it that attempts to prevent this change?
I just realised it says under the option that the device does not allow write cache settings to be modifed. Anyone know a way to override and do it anyway?
Comment
Tutorial Tools
Tutorial Category
Hard drive light constantly flashing ,reading hard drive during id Vista hardware & devices
Crashed hard drive...copied hard drive but can't access User area Vista General
SATA & eSATA hard drive speed poor Vista hardware & devices
very slow hard drive write speed Vista hardware & devices
Transferring files from Slave XP hard drive to new Vista Hard drive - primary Vista installation & setup
