Vista - Control Panel Icons
Comment
Old 05-05-2007
Brink
Control Panel Icons
How to Change a Icon in the Control Panel in Vista
Old 08-31-2008
claustrawberry
Vista Home Premiun 32bit
Re: Control Panel Icons
shawn, have u find mouse icon path?? because i really wanna change default mouse icon to mighty mouse icon from apple.. LOL :P
Old 08-31-2008
Brink
Hi Claustrawberry,
Sorry, I have not found the Mouse icon yet.
I like the Mighty Mouse idea though.
Old 08-04-2009
MrElectrifyer
Vista Home Premium x64
Hay Shawn, have you havd any luck in finding how to change the "View 32-bit Control Panel Items" icon? For some strange reason, when I changed the control panel Icon using your tutorial, the one in the start menu didn't change, all the other ones did, including the one on the desktop, just the start menu one and the 32-bit didn't change. Perhaps windows might be using a different registry key indicating the location of the icon. Got any clues where I could find it?
Please reply ASAP
Raashid
Old 08-04-2009
Brink
Hello Rasshid,
Sorry, but I have not had any luck finding those yet. I'll keep looking though.
Old 08-04-2009
MrElectrifyer
hey shawn, I think this software should do the trick:
http://download.cnet.com/IconPackage...-10031210.html
I am trying it right now
Old 08-04-2009
Brink
Rasshid,
Yes, that is a handy little app.
Old 08-05-2009
MrElectrifyer
yes it sure is handy, and by the way another way you could tryfinding the location of the icons is by going to the control panel in classic view, and right click on the icon you want to change and select create short-cut, when you create the shortcut, right cilck on it and select properties, then try changing the icon and you will be shown the current location of the icon
Comment
Tutorial Tools
Tutorial Category
No icons in control panel Vista General
How can I control the size of icons in Control Panel? Vista General
How to change icons in Control Panel Vista General
Vista RC2 No Control Panel Icons.. Vista General
Icons in Control Panel Vista General
