| Administrator | Power Options and Sleep Mode Problems How to Troubleshoot a Vista Sleep Mode Problem and Find a Solution Last edited by Brink; 04-07-2009 at 12:19 PM.. |
| Administrator | Re: Power Options and Sleep Mode Problems Orion, Here is the search link for the network drivers. Just enter 88E8001 for the lower part number search. Marvell: Consumer Driver Search Did you make sure that everything was set like the Sleep options in Step Two of this tutorial with S3 selected in the BIOS? Shawn |
| Member | Re: Power Options and Sleep Mode Problems Orion, Here is the search link for the network drivers. Just enter 88E8001 for the lower part number search. Marvell: Consumer Driver Search Did you make sure that everything was set like the Sleep options in Step Two of this tutorial with S3 selected in the BIOS? Shawn Any other ideas? -Orion P.S. Sorry for the delayed response. |
| Administrator | Re: Power Options and Sleep Mode Problems Orion, Did you try removing the TV Tuner card to see if that was the cause of this yet? It will be worth a try to see. Shawn |
| Member | Re: Power Options and Sleep Mode Problems |
| Administrator | Re: Power Options and Sleep Mode Problems Orion, I must admit that I'm stumped. I do not know what else to try other than a complete reinstall to hopefully eliminate the cause. Shawn |
| Newbie | Re: Power Options and Sleep Mode Problems Hello, I found this thread off google. I see others are having sleep problems too. I tried the methods listed and my monitor still will not wake up after sleep. I can hear that windows is awake by sound coming out of my speakers from tapping on the keyboard. However, the monitor no matter what I do still will not awake. I have unplugged it and turned it off and on with nothing. Comp specs: Dell Inspiron 530 (Desktop) Intel Core 2 Quad (Q6600) 4gig of A-Data ram Gigabyte 8600 GT (fanless) only keyboard + mouse plugged in through USB Everything is updated. Vista is running most current updates. Motherboard is updated. The built in graphics card is not disabled through Windows (Windows cannot even detect it) but rather selected to boot PCI first than onboard. BIOS has no option to physically disable it. So, I am stumped. It may be nVidia needs to update the drivers to a more current version to reflect SP1 (latest release is Dec 07). Other than that, no idea. |
| Administrator | Re: Power Options and Sleep Mode Problems Hi Specialmoose, Welcome to Vista Forums. ![]() You could try the latest 175.16 beta Nvidia drivers to see if that helps. http://www.vistax64.com/graphic-card...e-drivers.html Here's the Dell download link for you computer's software if you do not already have it. Drivers & Downloads= Hope this helps, Shawn |
| Newbie | Re: Power Options and Sleep Mode Problems When I push the power button to wake up my computer up from sleep, my wireless keyboard and mouse do not work. Any ideas where to start? Logitech MX 3200 usb connection Vista64 Home Premium Thanks |
| Administrator | Re: Power Options and Sleep Mode Problems Hi Doakh, Welcome to Vista Forums. ![]() I would check in the BIOS first to make sure that you have the USB Keyboard and Mouse options enabled. Next, check to make sure that you have all the latest drivers and software installed for the MX 3200. I noticed these files: 1. SetPoint 4.00BR 2. Firmware update for desktop mini receivers 3. Logitech® Desktop Messenger Here: http://www.logitech.com/index.cfm/43...=us,en?osid=13 Hope this helps, Shawn |
| Member | Re: Power Options and Sleep Mode Problems We'll find the problem ![]() Set Vista not to share media during sleep time and try. If NOK, allow hybrid sleep mode and try Do you have a tuner card? If yes deactivate it and try. Maybe the troubles are coming from the graphics card? What is your GC, are the drivers up to date? Look in the GC properties/details the power datas (mapping for S3 & S4 should be mentioned). Don't format as i think the result would be the same ![]() EDIT: Pls verify the size of your hiberfil.sys on C:\ hmm... vista doesn't share media already.. no tuner card.. i updated my grpahics card... how do i check GC properties and detaisl of the power data... ![]() alrite i shall not go and format.. lol and how do i verify the size of hiberfil.sys?? (i realli don't get computers)do u think it will work if i delete the hibernation thingy folder thingy in the disk cleanup thing and then reinstall or re'find' it? thank you!! |
| Tutorial Tools | |
| Tutorial | Category | |||
| Power Scheme-Sleep Mode | Vista General | |||
| Power Savings - Sleep mode | Vista General | |||
| Sleep Mode does not power down hard disk | Vista General | |||
| Power Setting for 'sleep-like' mode | Vista networking & sharing | |||
| Vista Sleep Mode Power Consumption? | Vista hardware & devices | |||
