Vista - Power Options and Sleep Mode Problems
Comment
Old 05-15-2007
Brink
How to Troubleshoot a Vista Sleep Mode Problem and Find a Solution
Old 05-21-2008
GB1099
Vista
Re: Power Options and Sleep Mode Problems
First of all this is a great forum and resource for Vista issues...I have learned a lot.
No here's my problem:
My home PC used to sleep and wake up perfectly. Then after a few months it started not sleeping and I had to go back to restore points....no hardware was ever changed.
Sometime it would not sleep, and other times it would not wake up the video card...never the same.
Finally I decided to load SP1. I kept getting stop errors until I reloaded Vista and then SP1 finally worked.
I have an Asus M2E MB with an ATI X1650 Video Card....all with the latest drivers.
The PC will sleep just fine but when it wakes up the monitor will kick on, but with a black screen everytime and I have to hard boot. I have gone through the tutorial (which is excellent) at the beginning of this thead in detail. I suspect it is a video card setting of some sort. I don't have any restore points where it ever worked.
Aside from buying another video card....does anybody have any other suggestions? You cannot imagine how many hours I have spent trying to fix this issue...thanks!
Old 05-22-2008
Brink
Hi GB1099,
Welcome to Vista Forums.
Since it is a ATI card, you might try uninstalling the video drivers and reinstall them without the CCC (Catalyst Control Center) option. I have heard of this causing problems on some computers. Maybe it is for you.
Old 05-22-2008
GB1099
Vista
Thanks for the suggestion...I uninstalled the ATI driver and manually reinstalled without using Catalyst...but unfortunately the same result.
PC will sleep, and awake, but the video is nothing but a black screen.
If you can think of anything else...Please let me know and I'll give it a shot.
Old 05-22-2008
Brink
GB1099,
Check to see if this may be the problem:
1. Open the Control Panel (Classic View)
2. Click on the Ease of Access Center icon.
3. Click on the Make the computer easier to see link.
4. Uncheck the Remove background images (where available) box.
5. Click Save.
Old 05-22-2008
GB1099
Vista
attached is a screenshot...I don't see that option.
BTW-I just noticed you live in TX...I live in Frisco so if you are anywhere close and want to come over and fix it...that would be cool....LOL!
Old 05-22-2008
Brink
LOL, GB1099
If I happened to be in the neighborhood I would, but I'm a good hour or more north of you and my bu** is dragging today.
Don't be , but just scroll down a bit and you will see it as the last item to uncheck.
Old 05-23-2008
GB1099
Vista
I guess I didn't bother to scroll down....it was late and I didn't see it...LOL.
Anyway it already was unchecked.....but good try anyway.
I would just go get another video card, but I know this one works with Vista and sleep mode.
This is the last Vista "issue" I have (at this point) and while many or most people bash the OS...I really like it.
Old 05-23-2008
Brink
GB1099,
Do you still get the blank desktop if you uninstall the video drivers in Device Manager and use the default driver given by Vista?
Old 05-23-2008
GB1099
Vista
When I tried that "sleep" was not an option if I remember correctly.
I'll try it again and see.
Old 05-25-2008
doakh
Vista Home Premium x64
Why do I need to close the Windows Sidebar for the USB keyboard and mouse to work after wakeup from "S3 Sleep".
Comment
Tutorial Tools
Tutorial Category
Power Scheme-Sleep Mode Vista General
Power Savings - Sleep mode Vista General
Sleep Mode does not power down hard disk Vista General
Power Setting for 'sleep-like' mode Vista networking & sharing
Vista Sleep Mode Power Consumption? Vista hardware & devices
