| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Power Options and Sleep Mode Problems How to Troubleshoot a Vista Sleep Mode Problem and Find a Solution Last edited by Brink; 04-07-2009 at 12:19 PM.. |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Powercfg & sleep problems NiGht kiD, No, but you can just set the network device to wake up the computer. (EX: Wake on LAN) |
| Vista™ Business 32-bit | Re: Powercfg & sleep problems Oh, there is no Wake on LAN in the advanced properties of my wireless card. |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Powercfg & sleep problems niGht kiD, Look under the Power Management tab for the Allow this device to wakeup the computer option. Shawn |
| Ultimate x64 | Hello! My Windows Vista Ultimate x64 goes to the Hibernation 10 minutes. A monitor turns off from the beginning of the Hibernation (it showed the Hibernation progress in Windows XP). The HDD activity led lights for 20 seconds from the beginning, then blinks rarely and then lights for 20 seconds again in the end. How to normalize the Hibernation? The RAM is 2 gb. CPU is Intel E6750. HDD is Western Digital Green Power 500gb SATA. Motherboard Asus P5K. Runing POWERCFG -H OFF and POWERCFG -H ON did not help. I tried with 'Suspend Mode' - 'Auto'. 'Repost Video on S3 Resume' - 'Enabled' and 'Disabled' 'ACPI Version' - 'Enabled' and 'Disbaled' 'ACPI APIC Support' - 'Enabled' in the 'Power menu' in BIOS setup utility v02.58 American Megatrends. Best regards, Dima Last edited by kop; 01-21-2008 at 05:09 AM.. Reason: Adding usefull information |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Power Options and Sleep Mode Problems Hi Dima, Welcome to Vista Forums. ![]() Are you saying it takes 10 minutes to hibernate once starting to? How long it takes Vista to save everything to the hard drive before hibernating depends on how many items are opened and how much it needs to save. Vista does not have a progress bar though. You can adjust how long you want to wait for the computer to enter hibernation in the Power Options. (STEP TWO) Please let me know anything I left out, Shawn |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Power Options and Sleep Mode Problems Updated 1-28-08 to include each sleep mode recommended settings in STEP TWO. Shawn |
| Vista x32 | Re: Power Options and Sleep Mode Problems I'll quote my post in this thread: Vista Wont Sleep, Want To Wake Up With MCE Remote I have found one more thing involved in the Vista waking up conundrum. It's a motherboard jumper. I was able to stop Vista waking up with the usual "power management" tab unchecking and wake-on-lan disabling. Several months later, I was leafing through my motherboard manual (as you do...) and read about a jumper allowing "USB Device Wake-Up". Turns out it was off by default. I set the jumper to on and hey presto, Vista stays asleep but I can still use the keyboard to wake it up! I do have to check "Allow this device to wake the computer..." but it now works as it should and doesn't wake up the machine unless I press the spacebar. My motherboard (Asus P5B-E) has one jumper for each set of USB ports, plus one for PS/2. I went over to a friend and her Asus has only one jumper for everything. But it works for her too. And the jumper was the only way to fix her Vista insomnia! |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Power Options and Sleep Mode Problems Starlionblue, Thank you for the tip addition. Shawn |
| Vista Ultimate 32bit SP1 | hi Brink Great resource you have here. My suggestion is in regards to step seven: putting the computer to sleep from the welcome screen when no users are logged in should eliminate having to deal with msconfig, no? Last edited by crashnet; 02-13-2008 at 07:01 PM.. |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Power Options and Sleep Mode Problems Hi crashnet, Welcome to Vista Forums. ![]() That's a good idea. It has been added to Step Seven in the tutorial. Thank you, Shawn |
| Tutorial Tools | |
| Tutorial | Category | |||
| Power Scheme-Sleep Mode | Vista General | |||
| Power Savings - Sleep mode | Vista General | |||
| Sleep Mode does not power down hard disk | Vista General | |||
| Power Setting for 'sleep-like' mode | Vista networking & sharing | |||
| Vista Sleep Mode Power Consumption? | Vista hardware & devices | |||
