| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Power Options and Sleep Mode Problems How to Troubleshoot a Vista Sleep Mode Problem and Find a Solution Last edited by Brink; 04-07-2009 at 12:19 PM.. |
| Vista Home Premium 32bit | Re: Power Options and Sleep Mode Problems Hi, I have HP Pavilion dv7-1140 and I have as well problems with hibernation. My computer always wake up at 1.00 a.m. (local time) and then doesn't sleep again and turn off after the battery is empty. ![]() There is no reason for wake up, I checked the events and the scheduled tasks as well and I found nothing. I wakes up even the LAN is off. I found out that few seconds before POWER TROUBLESHOOTER (ID 1) there is some TaskScheduler event "Module of tasks was ended" - ID of event 301. I really don't know what to do. Thank you in advance for your advice. Best regards Radek P.S.: I tried to change the time to few minutes to 1 a.m. and then I hibernate the NB. At 1.00.56 the NB woke up and then I checked with powercfg -lastwake and it schows 0. I think that there must be some task (hidden task), but I can't find the it (I have selected as well the option to show hidden tasks). ![]() Is there any possibility to see all tasks, but not through TaskScheduler? Thank you in advance for you help. BTW this forum is very helpful - thank you for it. ![]() Please, do you have any recommendation for me re my problem? Thank you in advance for your reply and have a nice day Radek |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Power Options and Sleep Mode Problems Hello Radek, You might also check in the power management options in the BIOS to make sure that nothing is allowed to wakeup the computer in there as well. Also check any programs that you have installed to see if they have something scheduled, ex: checking for updates. Hope this helps some, Shawn |
| Vista Home Premium 32bit SP2 | Re: Power Options and Sleep Mode Problems The start menu power button had the shut down option now all I have is sleep, I tried restore plans but stayed the same. |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Power Options and Sleep Mode Problems Hello Dwardu, Is shutdown also missing from the locations as described in this tutorial below? Shutdown Options - Start Menu |
| Vista Home Premium 32bit SP2 | Re: Power Options and Sleep Mode Problems Hello Dwardu, Is shutdown also missing from the locations as described in this tutorial below? Shutdown Options - Start Menu No it's there but why I can't change the start menu power botton back to shut down? |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Power Options and Sleep Mode Problems Click on the Restore plan defaults button to see if it may return afterwards. You will of course have to reset your settings though. |
| Vista Home Premium 32bit SP2 | Re: Power Options and Sleep Mode Problems |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Power Options and Sleep Mode Problems You can also use this Shutdown shortcut for now to if you like. You might also try a System Restore using a restore point dated when you think it may have been there. |
| Vista Home Premium 32bit SP2 | Re: Power Options and Sleep Mode Problems You can also use this Shutdown shortcut for now to if you like. You might also try a System Restore using a restore point dated when you think it may have been there. |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Power Options and Sleep Mode Problems You're welcome Dwardu. If I can find anything else on this, I'll post back with it. |
| Tutorial Tools | |
| Tutorial | Category | |||
| Power Scheme-Sleep Mode | Vista General | |||
| Power Savings - Sleep mode | Vista General | |||
| Sleep Mode does not power down hard disk | Vista General | |||
| Power Setting for 'sleep-like' mode | Vista networking & sharing | |||
| Vista Sleep Mode Power Consumption? | Vista hardware & devices | |||
