Vista - Power Options and Sleep Mode Problems
Comment
Old 05-15-2007
Brink
How to Troubleshoot a Vista Sleep Mode Problem and Find a Solution
Old 03-09-2008
Brink
Re: Power Options and Sleep Mode Problems
Hi Lio,
This is true. The hibernation file must be the same size as the amount of installed RAM since it saves everything from memory to the hard drive when the computer goes into hibernation mode directly or after awhile in hybrid mode.
It is safe to clean this file in Disk cleanup if you do not plan on using hibernation or Hybrid mode. You will still be able to use the normal Sleep mode though.
Hope this helps you,
Old 03-19-2008
brokentelephone
Vista Business 32bit
Firstly, thanks for putting in the effort to help random users deal with their problems, it is truly generous!
I have been having the sleep issue now for about two months. I purchased my laptop roughly a year ago, and the sleep function worked perfectly for quite a while. Then, one day it simply stopped working. I don't recall what updates I installed at that time which could've caused this, but I have tried everything, including removing all the windows updates, reinstalling them, but to no avail.
My particular issue is that I go into sleep, and when I try to load it up, the fans/power seems to go on, but the screen is off/blank. I tried hooking it up to a monitor, but that didn't help!
I have an LG Z1 Pro Express Dual computer w/Vista Business 32bit and 2 gigs ram. I've gone through every method in this tutorial, but nothing has worked thus far. I installed Vista SP1 this morning, praying that it would cure my ailing computer, but it hasn't!
The LG support system is not especially good, so I've gone and found this program that allowed me to upgrade the ATI graphics drivers to a version above the one supplied by LG. That didn't work!
Going into the BIOS, and also doing the "powercmg -a " program, I see that I only have S3 available now, though am unsure of whether S1 was available before.
I am literally at the edge of buying a new computer , as I constantly open and close my comp between classes, etc., and rebooting is just so annoying.
Also, when I shutdown the computer, sometimes it does a reboot, and i have to force power off by holding the power button. Each time I boot up, it says that windows hadn't powered off correctly (the black screen)!
I apologize for the long message, but am trying to remember all the issues i've been having so you have the most info to work with!!!
Thanks so much,
Josh.
Old 03-19-2008
z3r010
Josh
Have you installed Service Pack 1 yet as this cured all my sleep problems.
Old 03-19-2008
brokentelephone
Quote  Quote: Originally Posted by z3r010 View Post
Josh
Yah, I did install the Service Pack 1, but nothing changed. I was REALLY looking forward to it working though!
Take it easy!
Old 03-19-2008
Brink
Josh, you might see if adding S1 back into the BIOS will help any. I have both S1 and S3 sleep states selected.
Old 03-19-2008
brokentelephone
Quote  Quote: Originally Posted by Brink View Post
Hi! How would I go about doing this ?
When I did the 'powercfg -a' it said only S3 was available, and in my bios, there doesn't appear to be any options at all to modify sleep settings (aside from turning on/off S3).
Thanks in advance,
Josh.
Old 03-19-2008
Brink
Josh,
The available sleep states is dependant on your BIOS. It appears that your BIOS version only supports the S3 sleep state.
Have you tried doing a System Restore to a date before the problem started?
Old 03-20-2008
brokentelephone
Josh,
Will the System Restore cause all files that I've downloaded/saved/created disappear since the restore point ? I will need to backup big time if that is the case!
Thanks .
Old 03-20-2008
Brink
Josh,
I would backup what you do not want to lose to be safe. Some of these files could be wiped out in the restore.
Sorry,
Old 03-21-2008
brokentelephone
Josh,
Sorry,
Hi Shawn,
Happy Easter. Unfortunately, my restore points are very recent, only a few days, and therefore, wouldn't help as the problem is so long standing.
Any more suggestions? How do I know if my BIOS can be upgraded? I am losing my marbles! I cannot even turn off my computer.... might need to reformat once I have the time!
Comment
Tutorial Tools
Tutorial Category
Power Scheme-Sleep Mode Vista General
Power Savings - Sleep mode Vista General
Sleep Mode does not power down hard disk Vista General
Power Setting for 'sleep-like' mode Vista networking & sharing
Vista Sleep Mode Power Consumption? Vista hardware & devices
