Vista Forums
Vista Forums Home Join Vista Forums Donate Vista Tutorials Tags
Register at Vista forums...the world biggest Windows Vista resource Join Vista Forums Now
Vista Tutorial Categories Network & Internet Tutorials File & Folder Settings Tutorials Taskbar & Start Menu Tutorials Performance & Maintenance Tutorials General Tips Tutorials Programs & Features Tutorials Context Menu Tutorials Shortcut Tutorials Security & System Tools Tutorials Parental Controls Tutorials User Account Tutorials Hardware & Drivers Tutorials Appearance & Personalization Tutorials Backup & Restore Tutorials Music, Photo, Video and Media Tutorials Power Management Tutorials
Power Options and Sleep Mode Problems
Poll: Did this Tutorial help and work for you?
Poll Options
Comment
Tutorial Tools Display Modes
Old 05-15-2007
Brink's Avatar
Brink
Administrator
  Brink is online now
How to Troubleshoot a Vista Sleep Mode Problem and Find a Solution
Old 03-21-2008
Brink's Avatar
Brink
Administrator
  Brink is online now
Re: Power Options and Sleep Mode Problems
Happy Easter to you to Josh.
I would leave the BIOS as is for now until the sleep issue is worked out. No need to add another potential problem.
I must admit that I'm stomped to what the problem may be. I would backup everything and give a fresh reinstall with the SP1 to see how it works for you when you have time.
Old 03-22-2008
brokentelephone
Newbie
  brokentelephone is offline
Quote:
Brink
View Post
Darn! I wonder if it has anything to do with when my girlfriend dropped the computer ?
Anyway, will try that in a few weeks, and let you know if it works! Its never so bad to reformat completely anyway i guess!
Take care.
Old 04-07-2008
rightwinger59
Newbie
  rightwinger59 is offline
Thanks for the informative tutorial, but I'm afraid I could use some further help!
Here's my problem: I've updated my BIOS and graphics drivers, and when I set the ACPI setting in the BIOS to S1, sleep works fine (but the computer doesn't shut off - the fans and such are all still going), and when I set it for S3 it goes to sleep (computer shuts off), but when I try to wake it up it just hangs - the HD LED is on steady, nothing shows up on the screens (I'm running a dual monitor set up), and in fact the screens themselves don't even go out of sleep mode (power LEDs keep flashing). I have to hard-reset the computer to get it back. The same hanging symptoms occur when the BIOS is set to S1 & S3.
Any clues as to what might be causing this?
Old 04-07-2008
Brink's Avatar
Brink
Administrator
  Brink is online now
Hi rightwinger59,
Welcome to Vista Forums.
If this is after you installed SP1, then see if this may help you:
Re: Hibernation fails after installation of SP 1 - TechNet Forums
If you have a USB mouse, then see if this may apply to you:
A Windows Vista-based computer does not resume from sleep mode if you move or click a USB mouse as the computer is entering sleep mode
Old 04-08-2008
rightwinger59
Newbie
Quote:
Brink
View Post
Hi rightwinger59,
I do have SP1, but I was hoping that SP1 would fix this problem because it was doing exactly the same thing before the service pack. Unfortunately, the symptoms remain. Is this a video driver issue? nVidia hasn't come out with a new set of drivers since December, but again, this machine has been doing it since I built it.
I'm pretty sure it's not the mouse issue either, since I use the keyboard to put it to sleep and don't even touch the mouse.
Old 04-08-2008
Brink's Avatar
Brink
Administrator
  Brink is online now
Rightwinger,
If you have a USB mouse, it can cause problems like this even if it was not touched.
nVidia has a 174.74 beta driver version out for the 6,7 and 8 series that you can try to see if it is the video driver or not. You can see about it here:
http://www.vistax64.com/graphic-card...e-drivers.html
You might also consider running a Startup Repair to see if it finds anything wrong with the setup and fix it.
Startup Repair
Old 04-15-2008
scottm
Newbie
  scottm is offline
I'll admit my skill level is a zero. I'll probably take my computer back to Office Max and see if they can help. I have a HP laptop with vista. Last week I clicked the hibernation button just to see what it would do. Opening the lid, pressing any key does nothing. The computer just "dings". The word "Hibernation" is on the screen and the little blue circle to the left just rotates.
Any suggestions?
Thanks,
Scott
Old 04-15-2008
Cholin
Newbie
  Cholin is offline
At last Vista sleep mode now works so very many thanks for your guidance . Unfortunaltey i may have gone a step too far as I changed the setting in User Feed Synchroinization (dont ask me why!). I now get a message relating to my anti virus prog saying " A programme cant display message on your desktop". I changed the setting TO windows vista and believe I should have left well alone - just got a bit carried away but pretty sure this was the only deviation from your instructions! Problem now is I cant find where I accessed that setting! CAn you help? Thanks again
Old 04-15-2008
Brink's Avatar
Brink
Administrator
  Brink is online now
Hi Cholin,
Umm, I'm not sure where you changed that from the instructions above.
Check to see if you change this setting in Internet Properties, Content, Feed Settings. If so, just uncheck everything and click OK.
Old 04-15-2008
Cholin
Newbie
  Cholin is offline
NOpe, thats not it! I remember a whole list of settings options and each one was assigned to vista apart from this last one (user_feed_synchronisation) which was assigned to xp, windows 2000 and pos one other older windows system. Dont ask me why but thats what i changed to Vista.
Thanks again for your help so far!
Quote:
Brink
View Post
Hi Cholin,
Comment
Tags
hibernate, plan, power management, powercfg, sleep
Tutorial Tools
Display Modes
Tutorial Tutorial Starter Category Comments Last Post
Power Scheme-Sleep Mode Jerry Vista General 4 07-02-2008 08:41 PM
Power Savings - Sleep mode news.virginmedia.com Vista General 1 04-20-2008 01:13 AM
Sleep Mode does not power down hard disk Michelle Vista General 1 12-22-2007 06:07 PM
Power Setting for 'sleep-like' mode Bonnie. Vista networking & sharing 2 08-09-2007 09:18 PM
how to handle sleep mode of power manage viRtual Avalon 8 11-13-2006 02:55 AM
Vistax64.com is an independent web site and has not been authorized,
© Designer Media 2005-2008
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
