| Welcome to Vista Forums we are your forum to discuss Windows Vista x64 and x86 systems. |
| | Tutorial Tools | Display Modes |
| Administrator ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2007 Vista x64 Ultimate SP1
Location: Texas, USA | Re: Power Options and Sleep Mode Problems Orion, Here is the search link for the network drivers. Just enter 88E8001 for the lower part number search. Marvell: Consumer Driver Search Did you make sure that everything was set like the Sleep options in Step Two of this tutorial with S3 selected in the BIOS? Shawn |
| There are no dumb questions, just the people that do not ask them. Please post feedback to help others. | |
| Junior Member ![]() Join Date: Apr 2008 Vista Ultimate SP1 32 bit
Location: SF Bay Area | Re: Power Options and Sleep Mode Problems
Any other ideas? -Orion P.S. Sorry for the delayed response. | |||||||||||||||
Location: Texas, USA | Re: Power Options and Sleep Mode Problems Hi Specialmoose, Welcome to Vista Forums. ![]() You could try the latest 175.16 beta Nvidia drivers to see if that helps. http://www.vistax64.com/graphic-card...e-drivers.html Here's the Dell download link for you computer's software if you do not already have it. Drivers & Downloads= Hope this helps, Shawn |
Location: Texas, USA | Re: Power Options and Sleep Mode Problems Hi Doakh, Welcome to Vista Forums. ![]() I would check in the BIOS first to make sure that you have the USB Keyboard and Mouse options enabled. Next, check to make sure that you have all the latest drivers and software installed for the MX 3200. I noticed these files: 1. SetPoint 4.00BR 2. Firmware update for desktop mini receivers 3. Logitech® Desktop Messenger Here: http://www.logitech.com/index.cfm/43...=us,en?osid=13 Hope this helps, Shawn |
