Vista Tutorial - Recycle Bin
Comment
Old 05-27-2007
Brink
Administrator
Recycle Bin
How to Fix the Recycle Bin Icon Not Refreshing When Emptied
Old 03-25-2009
Roy_ricky
Stallion
Vista Home Premium 32bit
Re: Recycle Bin
sorry about that....
Old 06-24-2009
pacinitaly
Master
VISTA home prem 32bit SP2 --- XP Pro SP3 32bit
Arrow Re: Recycle Bin
This is a counter-measure to prevent accidental deletion of the Recycle bin icon from the Desktop in Windows Vista.
The Delete command from the Recycle Bin context menu in Windows Vista cannot be removed, but can be hidden by using a tweak. To hide the Delete command and replace it with a Search command, use these steps:
Recycle Bin Menu
~Carmine
Old 06-24-2009
Mr GRiM
Vista Supporter
Vista Ultimate x64
Re: Recycle Bin
Thanks, it was never needed anyway and you can disable it anyway from the change desktop icons in the personalization menu. (Works on Windows 7 as well )
Old 08-12-2009
maggiep35
Newbie
Windows Vista Ultimate 32bit
Smile Re: Recycle Bin
Shawn, Thanks so much for this. I have been frustrated by this small annoying recycle bin icon for ages! It always looked full even after I'd empty it. I did as you suggest with the manual icon changes and now it works again! Tar so much.
Old 08-12-2009
Brink
Administrator
Re: Recycle Bin
You're welcome Maggie, and welcome to Vista Forums.
Old 3 Weeks Ago
Twist3d
System Builder
Vista Ultimate
Re: Recycle Bin
None of these steps worked for me and I attempted them several times and read the whole tutorial.
I guess I'm simply screwed.
Old 3 Weeks Ago
Brink
Administrator
Re: Recycle Bin
Hello Matt,
Please describe your problem with the Recycle Bin completely. It may be another issue at hand.
Comment
Tutorial Tools
Tutorial Category
Recycle Bin Vista General
Recycle bin icon not filling/emptying when recycle bin is full/emp Vista General
recycle bin Vista General
RE: Recycle Bin Vista General
