Command Prompt
A List of Commands for Vista and How to Use them
These are commands that you use in the command prompt in Vista.
Some commands will not run unless they are used in an elevated command prompt. For how, see: How to Open a Elevated Command Prompt in Vista
EXAMPLE: Command Prompt Window
NOTE:
You can open a command prompt by typing cmd in the Start Menu Search box and pressing Enter.
1. Go to either link below for a list of Vista commands:​
NOTE: The list will have a description of what the command does. Click on the listed command to see how to use it.​
OR
You're welcome Toufen.
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    1 x 640Gb (SATA 300)
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Thank you Richard. Added. :)
Why thank you very much, Shawn!
Greatly appreciated! Glad I can be of (token!) assistance at least occasionally!
Richard
    Dell XPS 420
    Stock Dell 0TP406
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
