Vista Tutorial - Shortcut Arrow
Comment
Old 05-22-2007
Brink
Administrator
Shortcut Arrow
How to Remove or Change the Shortcut Arrow and Name in Vista
Old 07-04-2009
Witcher
Newbie
Vista Ultimate x64
Re: Shortcut Arrow
Thank you for this great tutorial. I was able to disable the shortcut arrows without using the program.
Old 07-04-2009
Brink
Administrator
Re: Shortcut Arrow
You're welcome Witcher, and welcome to Vista Forums.
Old 07-14-2009
junyii
Newbie
Vista Home Premium x64
Re: Shortcut Arrow
Hello,
I've been looking for a solution for awhile now (okay, a week..), but unlike the others - this one actually worked like charm. I used to second option, for the one first one didn't work when I tried it a few days back.
I signed up to drop a note of thanks. Those little arrows bothered me like none other, especially for my Adobe CS3 programs, which have nice little icons.
I'll be sure to visit this forum again if any other problems occur.
Thanks again!
Old 07-14-2009
Brink
Administrator
Re: Shortcut Arrow
You're welcome Junyii, and welcome to Vista Forums.
Old 07-26-2009
Kagi
Newbie
Vista Ultimate x64
Re: Shortcut Arrow
FxVisor64 worked for me.
Fxvisor32 did not work.
Old 07-26-2009
Brink
Administrator
Re: Shortcut Arrow
Hello Kagi, and welcome to Vista Forums.
That's strange since the download and links for FxVisor32 supports both 32-bit and 64-bit Vista. Do you also have a website link for FxVisor64 instead of a direct download link?
Old 07-27-2009
Kagi
Newbie
Vista Ultimate x64
Re: Shortcut Arrow
Shawn,
The developer's website, Frameworkx.com, is not working. I think the owners are now working for Citrix.
I haven't found FxVisor64 on the major download sites. Google found a website to download from.
Old 07-27-2009
Brink
Administrator
Re: Shortcut Arrow
Ok, thank you Kagi.
Old 09-14-2009
headshot
Windows 7 Ultimate 7600 x64
Re: Shortcut Arrow
Click the image to open in full size.
help me please, cos every time i clicked "Yes" on that dialog box, this thing always occured:
Code:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ComponentModel.Win32Exception: The system cannot find the file specified
   at System.Diagnostics.Process.StartWithCreateProcess(ProcessStartInfo startInfo)
   at System.Diagnostics.Process.Start()
   at VistaArrowGone.Form1.btApply_Click(Object sender, EventArgs e)
   at System.Windows.Forms.Control.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ButtonBase.WndProc(Message& m)
   at System.Windows.Forms.Button.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.4016 (NetFxQFE.050727-4000)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
FxVisor
    Win32 Version: 2.0.0.0
    CodeBase: file:///C:/Program%20Files/Frameworkx/Vista%20Shortcut%20Manager/FxVisor.exe
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Old 09-14-2009
Brink
Administrator
Re: Shortcut Arrow
Hello Headshot,
If you are just wanting to remove or restore the shortcut arrow, then you can do METHOD ONE instead.
If not, then did you do step 2 and run it as an administrator?
Comment
Tutorial Tools
Tutorial Category
Shortcut Arrow Vista General
Shortcut arrow Vista performance & maintenance
Shortcut arrow size Vista General
Better way to remove shortcut arrow Vista General
Shortcut arrow on icons Vista General
