Vista - Shortcut Arrow
Comment
Old 05-22-2007
Brink
Shortcut Arrow
How to Remove or Change the Shortcut Arrow and Name in Vista
Old 04-19-2009
alphecca
Vista Home Preimum x64
Re: Shortcut Arrow
hay,
i have been trying to download this version 2, and each i do it gives me the version 1.3!!! very annoying, and if i click on the 64 bit links the web page cannot be displayed! why is this. all my other web pages work. but when i try anything to do with frameworkx.com its like its not there. is it broken?
does anyone have a copy of version 2 they could send me?
or an alternative that deosnt involve the reg, because im pretty sure ial break it if i do that.
Old 04-19-2009
Brink
Re: Shortcut Arrow
Hello Alphecca,
I just tested the download version from the Softpedia Mirror (US) MSI link, and it is the 2.0 version.
Vista Shortcut Overlay Remover Download - Softpedia
If you just wanted to removed the shortcut arrows, then the .reg file downloads will do it for you automatically following the steps.
Old 04-19-2009
alphecca
Re: Shortcut Arrow
thank you very much brink,
i have just downloaded this and when implimenting recieved this error.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ComponentModel.Win32Exception: The system cannot find the file specified
at System.Diagnostics.Process.StartWithCreateProcess(ProcessStartInfo startInfo)
at System.Diagnostics.Process.Start()
at VistaArrowGone.Form1.btApply_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.3074 (QFE.050727-3000)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
FxVisor
Win32 Version: 2.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Frameworkx/Vista%20Shortcut%20Manager/FxVisor.exe
Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
i am running x64 vista home premium, i dont know if thats a problem.
any ideas?
if i press continue, and then log off and on or close and open explorer, the arrows remain
help
thanks
Old 04-20-2009
Brink
Re: Shortcut Arrow
Alphecca,
It appears that the program will not run on your system. Is it a not US version of Vista?
You can use METHOD TWO instead to remove the shortcut arrows. I had made .reg files to download and merge to make it simple and not have to play in the registry tp do it.
Old 04-20-2009
alphecca
Re: Shortcut Arrow
hi again,
the version is purchesed in the US, as is the laptop.
never mind i tryed to reg edit as you sugested. worked like a pro.
thanks a lot!
also on a side note, do u know of a free decent video converter, .mov files to .mpeg or .wmv?
one thats can deliver high quality without a watermark.
thanks so much!
Old 04-20-2009
Brink
Re: Shortcut Arrow
You're welcome Alphecca. I'm happy to hear that you got it sorted.
Sorry, but I do not know of any video converter though.
Old 04-21-2009
Beebe
Vista Ultimate x64
Re: Shortcut Arrow
Hi all I just enrolled today. I have read this fine tutorial, and have had nothing but problems. When I was running 32bit I had no problems with the FXVisor. I am sure I have version 2.0 which works with 64bit. I am now running 64bit Ultima. I ran the program in my user acount and I get a unhandled exception error. I continue, log off and still the arrows. AHHHHHH!!!
During my Google travels, it was saying you need to run the program as an Administrator. Well, I couldn't find out how to enable that account. Then Google again brought me here and I found the tutorial on how to enable it in CMD line. Tried that and still same error. I'd post it but it is long and is basically the same as others have posted.
What is a guy to do? I know you have a second option here, but as you can see I'm anal about shortcut arrows, so the same applies trying to figure this out. I was thinking it is a .net framework issue. I do not have .net 1.1 installed is this a problem?
Thanks for the help.
Beebe
Old 04-21-2009
Brink
Re: Shortcut Arrow
Hello Beebe, and welcome to Vista Forums.
Yes, the second option will work just fine to remove the shortcut arrows.
However, if you would like to see if we can get the first option working for you, then check the Microsoft .NET Framework 3.0 option in Windows Features to see if the Frameworx program may run for you afterwards. If not, then just uncheck the option and uninstall the Frameworx program to be back to where you were before.
Old 04-21-2009
Beebe
Vista Ultimate x64
Re: Shortcut Arrow
Thank you Shawn. I will try it when I get home from work. These forums are incredible.
Dave
Old 04-21-2009
Brink
Re: Shortcut Arrow
Ok Dave. Please let us know how it turned out for you.
Comment
Tutorial Tools
Tutorial Category
Shortcut Arrow Vista General
Shortcut arrow Vista performance & maintenance
Shortcut arrow size Vista General
Better way to remove shortcut arrow Vista General
Shortcut arrow on icons Vista General
