Vista - Recycle Bin Menu
Comment
Old 05-31-2007
Brink
Recycle Bin Menu
How to Replace Delete in the Recycle Bin Context Menu in Vista
Old 03-04-2008
Brink
Re: Recycle Bin Menu
bam4846,
Sorry, you can only replace it to remove Delete. Search is not a bad alternative.
Old 03-04-2008
Bare Foot Kid
Vista 64-bit Ultimate Win7 64-bit Ultimate XP SP3 32-bit Pro
Hi Shawn, Thanks for you'r offer. But it's not worth the trouble !!!
Thanks anyway, Ted
Old 03-04-2008
davehc
Vista 64
Quote  Quote: Originally Posted by bam4846 View Post
Only tried the one since it was moderately useful to me.
I really would just like the delete option removed with nothing else added. Unless I could replace it with a "winning lottery numbers generator" option. That would come in handy. Anything else just makes a large pain-in-the-ass into a small pain-in-the-ass.
Thank you for your reply.
Just run this reg file (trust me!) the del will be gone.
File Type: zip recycle.zip (726 Bytes, 20 views)
Old 03-04-2008
Brink
Hi Dave,
Yes it will. It's the same as the replace with Search option.
Old 03-13-2008
ggbib
Vista Ultimate x64 SP1
All 4 of the .reg's work here. Is there a way to get all 3 tweaks on the menu at once?
J
Old 03-13-2008
Brink
Hi J,
You can only use one of these to replace Delete with, but you can use the link below to add the ones you did not select to the context menu instead.
Recycle Bin - Add program to menu
Old 03-22-2008
philosos
Vista Ultimate 32bit
Worked just fine for me--thanks.
Old 03-22-2008
Brink
Your welcome Philosos. Thank you for the feedback.
Old 04-30-2008
ckc
Vista Home Premium 32bit.
After I deleted my recycle bin about a 100 times I found your solution and replaced delete with Clear system temps.and repaired the icon.This is the best thing ever,what a simple fix for big pain in the butt. Vista Home Premium 32 bit and it works just fine,thanks
Old 04-30-2008
Brink
Your welcome CKC, and welcome to Vista Forums.
I'm glad to hear that it was able to help you.
Comment
Tutorial Tools
Tutorial Category
Empty Recycle Bin - Add to Desktop Context Menu Tutorials
No "delete" option in Recycle Bin Menu General Discussion
Recycle Bin - No menu or properties! PLEASE help! General Discussion
Recycle bin icon not filling/emptying when recycle bin is full/emp Vista General
Recycle Bin - Add program to menu Tutorials
