| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Recycle Bin Menu How to Replace Delete in the Recycle Bin Context Menu in Vista Last edited by Brink; 04-15-2009 at 02:48 AM.. |
| Ontario | Re: Recycle Bin Menu Shawn, Thanks for this. Replace Delete with Disk Cleanup worked perfectly for me in Vista Home Premium SP1 (32 bit). I have many times in the past stupidly deleted the recycle bin icon when I meant only to empty it, so your hack is much appreciated! ![]() |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Recycle Bin Menu Your welcome MacSimi, and welcome to Vista Forums. ![]() Shawn |
| Vista 32Bit Ultimate x64 | Re: Recycle Bin Menu Only tried the one since it was moderately useful to me. I really would just like the delete option removed with nothing else added. Unless I could replace it with a "winning lottery numbers generator" option. That would come in handy. Anything else just makes a large pain-in-the-ass into a small pain-in-the-ass. Thank you for your reply. |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Recycle Bin Menu Hi Gate1975mlm, Welcome to Visa Forums. ![]() You would just use the REG download in step 4 to restore the default Delete. ![]() Hope this helps, Shawn |
| Vista Home Premium 32bit | Although I'm pretty computer savy and have been using a computer of one kind or another since 1981, after getting my new computer with Vista, I've been deleting the recycle bin over and over. A lot of the time, I would be extra careful to only click on empty, but my hand is faster than my eye & brain! Today I got smart and decided to do a search to find out if there was a fix for this. The first one I came across entailed me editing my registry. The second one led me to this website where I corrected the problem in less that 2 minutes (which included the downloading time). Thanks so much for making my life easier! Viveca |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Recycle Bin Menu You're most welcome Viveca, and welcome to Vista Forums. ![]() Shawn |
| Tutorial Tools | |
| Tutorial | Category | |||
| Empty Recycle Bin - Add to Desktop Context Menu | Tutorials | |||
| No "delete" option in Recycle Bin Menu | General Discussion | |||
| Recycle Bin - No menu or properties! PLEASE help! | General Discussion | |||
| Recycle bin icon not filling/emptying when recycle bin is full/emp | Vista General | |||
| Recycle Bin - Add program to menu | Tutorials | |||
