br> br> |
| | Tutorial Tools | Display Modes |
| The Contemplator | Re: Welcome to the 32 bit and 64 bit Vista Forums Tutorial Section Hi John & Shawn, I have just submitted my first tutorial, 'How to Import & Export Favorites in IE7', but unfortunately I was unable to select the correct header image (I wanted the IE icon) because the browse function was missing under the 'Header Image' section. Other than that, I found this to be straight forward, and will tidy it up when I have more time. Another question. I have used 18 images in this tutorial. Do these images remain in my allocated image store, or can I empty this without my images being lost? Dwarf Last edited by Dwarf; 04-20-2008 at 01:29 PM. Reason: Additional question. |
| BOFH | Re: Welcome to the 32 bit and 64 bit Vista Forums Tutorial Section Nice work Dwarf I'm not sure what your talking about with regards to the image store, I know I have set no limits on the amount of pics etc a user can upload (although this may change next week with the new version of vbulletin) so for now just forget about it. John |
| Administrator | Re: Welcome to the 32 bit and 64 bit Vista Forums Tutorial Section Hi Dwarf, Great Tutorial. I added the IE7 icon to the tutorial, and the Favorites User Folder as an option to be selected to if you wanted to. If you delete any of the Attachments in your user Control Panel, then they will also be deleted in any of your posts and tutorials that they are in. Hope this helps, Shawn |
| The Contemplator | Re: Welcome to the 32 bit and 64 bit Vista Forums Tutorial Section Thanks John & Shawn for the answers to my questions. The response about attachments may also help others who were thinking about the same idea. Also, thanks to Shawn for correcting the header image for me. Dwarf |
| The Contemplator | Re: Welcome to the 32 bit and 64 bit Vista Forums Tutorial Section Hi John & Shawn, I have been working on a new tutorial as suggested by one of the forum members, and unfortunately I have come across a problem in that my allocated attachments space is going to be exceeded. How do I avoid this problem without losing any of my attachments? Can this be done by using the 'Upload File from a URL' option (can you please explain how this option works, and what kind of files can you upload), or is there some other method such as storing the images on a remote server and linking to that instead? If this is the option, how does it work, and are there any free solutions available that you recommend? Dwarf |
| The Contemplator | Re: Welcome to the 32 bit and 64 bit Vista Forums Tutorial Section Thanks John. I have now finished the Tutorial and have had no problems with the attachments. I have also re-done the images for you so that the red band isn't showing, although I did include one image with it just for illustration purposes to show the default settings with the 'Snipping Tool'. Thanks also for amending the icon at the start, and also for the assistance with the initial image. Dwarf |
| Tags |
| donate, forums, general tips, tutorial, welcome |
| Tutorial Tools | |
| Display Modes | |
| Tutorial | Tutorial Starter | Category | Comments | Last Post |
| What's going on in Vista Forums?! | splosher | General Discussion | 6 | 06-29-2008 07:55 PM |
| If only vista was like its forums! | Spencer | General Discussion | 11 | 06-22-2008 01:33 PM |
| Why does Vista require Forums? | P. Jayant | General Discussion | 6 | 02-08-2008 07:35 PM |
