Welcome to the Vista Forums Tutorial Section !!
NOTE
| | Even though this site is dedicated to 64 bit Vista, all the tutorials will work with both the 32 bit and 64 bit Vista unless otherwise stated in the upper right corner of the tutorial. EXAMPLE:  |  |
How to Register to Post : NOTE
| | You do not need to be a registered member of this forum to view any of these posts. You only need to register to be able to post anything in this forum. The registration is free and easy. No personal information is shown to the public except for what you decide to post or reveal. We welcome any comments. Please see the FAQ Page for additional help and questions not covered here. |  |
Vista Forums Home Page
Vista Forums Registration Page and
Vista Forums Forum Rules and
Vista Forums Donate to Help Support
Just click on the registration link here or on the Home page and follow the instructions to register as a member.
How to Post a Reply to a Tutorial : NOTE: When you click on a tutorial to open it, you will have these options to post a reply or question about the tutorial or another posted reply.
Post Reply is located in the upper and bottom left corner of the tutorial page, and in the bottom right of the posted tutorial. You would click this to post a reply to the tutorial without a quote.
These are located at the bottom right corner of each reply post in the tutorial. These are pretty much the same as in the rest of the forum.
1. QUOTE = Allows you to post a reply with a quote of that post.
2. Multi-Quote = Allows you to post a reply with multiple quotes from the posts that you selected. Use this by clicking on the Multi-Quote button in the post to turn it red with a
+ to select it. Repeat for any other post you want to include in the reply's quote. When done click the
QUOTE button.
3. Quick Reply = This will take you to the
Quick Reply box at the bottom of the tutorial page. It will let you make a quick reply to the tutorial without any quotes.
How to Create a New Tutorial : NOTE: Creating a Tutorial is for posting a tip or trick to share with others to help them. Please do not create a tutorial has a question to a problem. The Vista Forums is used for questions not related to the tutorial, or new questions.
New Tutorial is located in the upper and bottom left corner of the
Vista Tutorials, not while you have a tutorial opened. Click this to create a new tutorial.
1. Header Image - To select a icon for your tutorial. Click
Browse to upload a image of your own.
2. Options - To type in a
Title,
Byline and other information about your tutorial. Be sure to select what versions of Vista your tutorial will apply to for it to post. Type in a desciption of your tutorial in the
synopsis section to have it shown in the
Tutorial in Category display.
3. Post New Tutorial or
Edit Post - This is just like posting in the forum sections. Type in your tutorial here. When done, click the
Submit New Tutorial button to post your new tutorial.
Video Tutorials :
We have added a Flash video to some of our tutorials to give you instuctions through a instructional video. After you click on the
Click to Play button in the video, you can use the video player like any other player with Forward, Reverse, Pause, etc.
You will need to have a flash player installed to use the video. See:
Adobe Flash Player Download Center
Navigating :
Each tutorial is categorized by it's title name. You can look for a tutorial by either the
alphabetized tutorial title (top),
Category Icon Tags (middle), by
page (bottom) or by the
Tutorial Index.
Search Feature :
To search for a key word or phrase that may be in a tutorial, click the
Search this Category button. Select if you want the results to
Show Tutorials or
Show Posts. Type in the word or phrase you are searching for and click
Go.
Tutorial Tools :
To select one of these options below for the tutorial.
So Please Scroll, Read, Post, Reply and ENJOY !! The www.vistax64.com Team. P.S.
If you notice any typos or errors in the tutorials, please feel free to
Report them so they can be corrected.
