Default Programs
How to Associate a File Extension Type With a Program in Vista
This will show you how to associate a file extension type or protocol to open with a program that you want it to open with by default.
These Default Programs association settings are a per user setting and not applied to all users.
The program you select will need to be able to support that file extension for it to open it. For example, .TXT with Notepad or Wordpad. It would not open with MSPaint.
METHOD ONE
Through a Download
1. Go to the link below to select a file extension to download a .reg file for to merge and restore it's default associations for.​
METHOD TWO
Through Open With
To add a program to the Open With menu list, see METHOD TWO here: How to Add a Program to Open With in Vista
1. Right click on a file, with the file extension type you want to change, that you want to open.​
2. Click on Open With and click on the program you want to open it if listed. (See screenshot below)​
NOTE: This will only open the file with the selected program for just this one time.​
3. If the program is not listed, then click on Choose Default Program. (See screenshot above)​
A) Click on the Browse button. (See screenshot below)​
B) Navigate to the program's .exe location that you want to open the file and select it. (See screenshot below)​
C) Click on Open.​
4. To Make this the Default Program to Open this File Extension -
A) Check the Always use the selected program to open this kind of program box. (See screenshot below step 3A)​
B) Go to step 6.​
5. To Open this File Extension with this Program for just this Time Only -
A) Uncheck the Always use the selected program to open this kind of program box. (See screenshot below step 3A)​
6. Click on OK. (See screenshot below step 3A)​
METHOD THREE
Through Default Programs
2. Click on the Default Programs icon.​
3. Click on the Associate a file type or protocol with a program link. (See screenshot below)​
4. Click on the file extension type you want to change the association for what .exe program opens it. (See screenshot below)​
NOTE: It may take a moment to load up.
5. Click on the Change Program button.​
6. If listed, select the program you want to be associated with (opens) the file extension. (See screenshot below)​
A) Check the Always use the selected program to open this kind of program box and click OK.​
7. If the program is not listed, then click the Browse button and navigate to the .exe of the program you want as the default to open the file extension.​
A) Select the program.​
B) Click on the Open button. (See screenshot below)​
C) Check the Always use the selected program to open this kind of program box and click on OK to apply. (See screenshot below step 7)​
Hello
Can u tell me please , what is the Default program that open EXE Files !
i have this problem here in my Windows Vista , whereas MSN Messenger is the Default program for EXE Files ,
i Can not Open any program ! , even system Restore !!!!!
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
Your welcome Eng.mxz911.
Hi
I have a problem with the association files
I have 2 computers that run vista 32 home, and with one I can open the .dat files with notepad, and with the other one I can too but there is no way to save the association between notepad and .dat
The Always use the selected program to open this kind of program box is alwaus grey and I can't clic it in
the computer is brand new and it's an Acer, I'm admin on it and tryed lot things but nothing to do
I tested all that is in this great tread but it didn't helped me
Do you have any idea ?
Thanks
Peter
Hi Peter, and welcome to Vista Forums.
Try Method Two to see if you can manually set the .dat file extension to have the Current program set at Notepad (C:\Windows\System32\notepad.exe).
Hi
thanks for fast reply on an old post
I forgot to say I tryed it
.dat is not in list so I can't do the change program
My problem is that the "always use ..." box is disabled, don't know why, I looked all the settings in the computer, I'm admin on it but no way to find out
Thank you for help
Peter,
A .DAT file is a file that has arbitrary data. Which means it’s not associated with any one particular program or application. That would be why it's not listed and will not let you check the "Always open with" box.
While it's best to open a .dat file with the program that created, Notepad or WordPad may be able to let you see some of the data in the file without it being a garbled mess.
Yes sure I can open it with notepad
I tell each time manually to vista to open it, it looks for a program then I tell him with notepad and it works
My problem is that I have to open one thousand .dat files everyday, and it would be very easier for me to double clic on it to open it, and not to loose time to tell vista to open it with notepad
I have 2 comps here and I'm working with the old one that is really slow but it opens the file with a double clic, there is vista on it also and .dat is listed in the association box ... Now I bought a brand new and fast computer and I just want it to open the files like the old one does
I'm just unable to explain why the box is grey and I can't clic it
Thanks
Peter
Peter,
The problem is that you do not want .dat files to be associated to be opened by only on default program. Since these are data files, doing so may cause a program to no longer work since that specific program will no longer be able to open it's .dat files for it. :(
Peter,
Peter,
Vista will not let .dat files be associated to just one program as per the stated reason above. :(
You can only manually "Open With" a single .dat file at a time with a program you want instead.
Ok, but I can with my other computer and vista ...
sometimes there are curious things with computers ;)
Thanks you Brink for your help, explanations and time
Peter
Hey, my DLL files have been associated with Windows explorer by mistake, and if i double click them by mistake, it keeps opening multiple explorer processes non-stop til i shut down. DLL files arent listed in default programs, so i dont know how to reset it. please help!!!
thanks in advance
    Dell XPS M1530 (Laptop)
    Core2Duo T8100 (2.1 GHz)
    Nvidia 8600M GT @ 625/1300/920
    1280x800 (bummer, higher res wasnt available)
    250GB
    2MP Integrated Webcam
    TouchStrip Fingerprint Reader
Thanks a lot! Worked like a charm
    250GB
You're welcome Nhnt11. :)
hi again, I just realized that DLL files now have the default icon (the blank page). Aren't they supposed to have a kind of page with gears on it? How do I get the icon back? I tried resetting the icon cache, but it didnt help...
    250GB
