Internet Explorer Menu Bar - Always on Top
How to Put the Menu Bar Always on Top in Internet Explorer 8
This will show you how to put the Menu bar on the top of Internet Explorer 8 instead of under the address bar by default in Windows 7 and Vista.
This will not work in Internet Explorer 9 and newer.
EXAMPLE: Default IE8 Menu Bar
EXAMPLE: IE8 Menu Bar on Top
METHOD ONE
Using a REG File Download
1. To Put the Menu Bar on Top
MenuBarOnTop.reg
download
B) Go to step 3.​
2. To Restore the Default Menu Bar Position
MenuBarDefault.reg
download
4. Right click the on the downloaded.reg file and click on Merge.​
5. Click on Run, Continue (UAC-Vista) or Yes (UAC-Windows 7), Yes, and then OK when prompted.​
7. Close and reopen Internet Explorer to see the changes.​
METHOD TWO
Manually Using Registry Editor
1. Open the Start Menu, then type regedit in the search box and press Enter.​
2. If prompted by UAC, click on Continue (Vista) or Yes (Windows 7).​
3. In regedit, navigate to the location below. (See screenshot below step 4C)​
Code:
[/INDENT][/INDENT]
[INDENT][INDENT]HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser[/INDENT][/INDENT]
[INDENT][INDENT]
4. To Put the Menu Bar on Top
A) In the right pane of WebBrowser, right click on a empty area and click on New and DWORD (32-bit) Value.​
B) Type ITBar7Position and press Enter.​
C) Right click on ITBar7Position and click on Modify.​
D) Type 1 and click on OK. (See screeshot below)​
E) Go to step 7.​
5. To Restore the Default Menu Bar Position
A) In the right pane of WebBrowser, right click on ITBar7Position and click on Delete. (See screenshot below step 4C)​
B) Click on Yes to confirm the deletion.​
6. Close and reopen Internet Explorer to see the changes.​
  • MenuBarOnTop.reg
  • MenuBarDefault.reg
Re: Internet Explorer Menu Bar
will this menu bar on top fix work with 64bit Vista? I notice it says 32bit in the procedure.
Thanks, atashiusa08
    HP Pavilion a6500f
    4 gig
    19" flat panel
    500 Gig
    HP keyboard
    Logitech Track Ball
    Sloooooow Dial-up
Hi Atashiusa08, and welcome to Vista Forums.
Yes, it will work in both the 32 bit and 64 bit Vista. Each tutorial has an Applies to box towards the upper right corner to help let you know what the tutorial should work with. :geek:
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
Brink, Dear Boy.....
You've done it again..nice, neat and clean lines. Used the Download, and all done in less than a minute. Page a joy to behold and old eyes immediately pick-up on line text. Wonderful. Grazzi, Sassofalco.
    nVidia GeForce Go 7300, 128MB
    1280x800x60Hertz [max.]
Your welcome Sassofalco.
Updated for Internet Explorer 9 in Windows 7 and Vista. :)
Worked great Shawn, Thanks!
    Intel I5-2500K @3.3GHz
    Asrock P67 Extreme4
    EVGA GeForce 750 Ti SC 2GB
    auria eq2367
    250GB Samsung 850 EVO SSD
    1TB WD Blue
    1TB Hitachi
    SeaSonic X 650W 80 Plus Gold
    Corsair Obsidian 750D
    Logitech Wireless Mouse M310
    Laptop specs: HP g7-1365dx /
    CPU: AMD A6-3420M APU with Radeon(tm) HD Graphics /
    RAM: Crucial 8Gb (2x4Gb) /
    SSD: Crucial M4-CT128M4SSD2 ATA Device/ FW 000F /
    GFX: AMD Radeon HD 6520G /
    OS: Windows 10 Pro x64
You're most welcome Derek. Thank you. :)
Nice! Thanks! BUT: IE9 has really done me over! I think I might have to perform a System Restore to before I installed it! It has messed up a whole load of things!
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    1 x 640Gb (SATA 300)
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
I'm sorry to hear that Richard. Hopefully the next IE9 release will work better for you. :(
Hopefully! I did try and force it on, maybe all the problems was a warning. First the installer hung. Then I tried again. This time it worked, but sent me to the Microsoft Support website for an update for Vista SP1. I then tried the alternative installer. This also hung. I then ran the installed extracted to the Temp folder. This worked. Restarted my machine, as per the instructions, and suddenly User Account Control had turned on. Tried to turn it off, but (apparently) it already was off. Hmmm. ComboFix then picked up that my EnableLUA registry value was missing, so I put it back in again. Restarted. Problem fixed! Then had to reinstall IE9 from the Temp folder again (I don't really know why, it seemed to have disappeared) but before I could do this, I had to run the installer again, which hung, to produce the Temp files. Maybe all this should have taught me, but no, I plough (plow) on with the install. Restart. Suddenly my screen is slightly odd. I could quite place a finger on it.
Icons have moved into four rectangles, so something has definitely happened. The writing on all of my icons is slightly blured, and everything is very slightly too big. resolution is apparently correct. After fiddling with all my settings, and disabling my second monitor, and then re-enabling it, I have finally got back to what it was (or recreated whatever registry key become corrupt)
So, IE9 is working! Just waiting to find out if anything else interesting has happened to my registry. If it has, I think it will be "Hello System Restore! Goodbye IE 9!"
Ah well! All fixed for the moment!
Richard
    Dell XPS 420
    Stock Dell 0TP406
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
