| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Auto Tuning - TCP/IP receive level How to Enable or Disable the Receive Window Auto Tuning Level in Vista Last edited by dmex; 07-04-2008 at 05:00 PM.. |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Auto Tuning - TCP/IP receive level Hi Stat, Welcome to Vista Forums. ![]() If you are not having any problems with your network connection, then I would not be to concerned with it. You can try it set as enabled and restricted to compare it to how it is running now as set to disabled to see which setting runs better for you. Hope this helps, Shawn |
| Vista Home Premium x86, Vista Ultimate x86 | Re: Auto Tuning - TCP/IP receive level Hi Stat, Welcome to Vista Forums. ![]() If you are not having any problems with your network connection, then I would not be to concerned with it. You can try it set as enabled and restricted to compare it to how it is running now as set to disabled to see which setting runs better for you. Hope this helps, Shawn |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Auto Tuning - TCP/IP receive level Hi Stat, Welcome to Vista Forums. ![]() If you are not having any problems with your network connection, then I would not be to concerned with it. You can try it set as enabled and restricted to compare it to how it is running now as set to disabled to see which setting runs better for you. Hope this helps, Shawn You may be having a temporary DNS server address issue with your ISP. Try these Open DNS addresses to see if you can connect to the website with them. Just click on the Computer, or Router if you use one, and follow the instructions on how to enter the addresses into your network device properties page. https://www.opendns.com/start Hope this helps, Shawn |
| Vista Home Premium x86, Vista Ultimate x86 | Re: Auto Tuning - TCP/IP receive level Hi Stat, Welcome to Vista Forums. ![]() If you are not having any problems with your network connection, then I would not be to concerned with it. You can try it set as enabled and restricted to compare it to how it is running now as set to disabled to see which setting runs better for you. Hope this helps, Shawn You may be having a temporary DNS server address issue with your ISP. Try these Open DNS addresses to see if you can connect to the website with them. Just click on the Computer, or Router if you use one, and follow the instructions on how to enter the addresses into your network device properties page. https://www.opendns.com/start Hope this helps, Shawn No luck with that one. Great site btw. As soon as I type in the url for my forum I get the "internet cannot display page error." But then I hit refresh and it loads S-L-O-W-L-Y and all the images do not show up. |
| Vista Home Premium 32bit | Re: Auto Tuning - TCP/IP receive level Don't really understand the importance but in my TCP Global Parameters it shows Chimney Off load State as disabled. Never changed anything there, is "enabled" important? |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Auto Tuning - TCP/IP receive level Hi hdbg62, This will help explain more about Chimney Offloading. It is recommended to have it enabled though. http://blogs.dirteam.com/blogs/sande...rver-core.aspx Use the instructions in the tutorial above, but use these commands instead: Enable: netsh interface tcp set global chimney=enabled Disable: netsh interface tcp set global chimney=disabled Hope this helps, Shawn |
| Vista Home Premium 64bit | Re: Auto Tuning - TCP/IP receive level Omfg i disabled this it was set at high and i also disabled page clearing or whatever and yea but before i did this i was at around 13MBs download and 1MB upload. Now... IM AT 30MBs download!!! But still only 1MB upload. Thank you so much you seriously make me happy ^_^. Now i can tell my friends that i almost know for a fact my connection is better than theirs lol Also i disabled the reserved bandwidth. Thank you so much again!!! |
| Vista Home Premium 32bit | Re: Auto Tuning - TCP/IP receive level What are we talking about here? Disabled what? "TCP/IP" or "netsh interface tcp set global chimney"? Please, do reply. |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Auto Tuning - TCP/IP receive level Your welcome Masterjego, and welcome to Vista Forums. I'm happy to hear it. Shawn |
| Vista Home Premium 64bit | Re: Auto Tuning - TCP/IP receive level Well now i just went down to 8MBs i dont know what happened because before i made the changes last time i tested it and then made the changes and got the boost. But now i put the TCP/IP autotune setting to experimental and a decent portion of the speed came back i tried the settings i had before and nothing worked... I just dont get computers or the internet anymore lol. Last edited by masterjego; 07-10-2008 at 06:05 PM.. |
| Tutorial Tools | |
| Tutorial | Category | |||
| Problems with TCP Window Auto-Tuning since installing sp2 | Vista General | |||
| TV Tuning Box | Media Center | |||
| Vista Auto Tuning (Int. Adv. Users) | Vista General | |||
| Receive Window Auto-Tuning on Vista | Vista networking & sharing | |||
| Mic Volume Level Auto-Adjusts | Vista music pictures video | |||
