Vista - Auto Tuning - TCP/IP receive level
Comment
Old 06-21-2007
Brink
How to Enable or Disable the Receive Window Auto Tuning Level in Vista
Old 10-17-2008
hispanico
Vista Ultimate 32bit
Re: Auto Tuning - TCP/IP receive level
I Brink this is my situation:
I have vista ultimate 32bit. My connection is FastWeb 6Mbit and my son play a lot in internet like quake, cod4 etc...which is the best configuration to have good and high connection ??
Thank a lot
Hyspa
Old 10-17-2008
Brink
Hello Hyspa, and welcome to Vista Forums.
The settings you have are the default settings and usually do a great job set that way. As a test you can see how your network runs with the Receive Window Auto-Tuning Level (Livello regolazione automatica finestra ricezione) set with the steps in the tutorial to see if it may be better with one of them instead. If no, just set back to the default Normal setting.
Old 11-13-2008
panais
Windows 7 Ultimate 64bit
Quote  Quote: Originally Posted by Brink View Post
Hi Mafia_Boy,
That just means that you had ran Step One in the tutorial to restrict the TCP/IP Auto tuning. If you want the normal settings again, run Step Three.
Would this help with (utorrent slows my internet)?
Because everytime i start utorrent my internet sloooows.
With Bitcomet everything works fine Bitcomet doesn't slow my internet.
How and why is that?
Old 11-13-2008
Brink
Hi Panais,
You could try the setting set either way to test to see for sure, but it is most likely a setting in the utorrent program that is not set for optimum performance. You should post a new thread in the Software or Network & Internet forum about this program to see what others may recommend for it's settings.
Old 11-28-2008
mohanmathew
Ultimate32
I have a similar problem with my Vista Ultimate. It takes nearly 1 minute or more to connect to my wireless point. At the same time other laps in my house can be connected instantly. Mine is lenovo, and others are Sony and Dell. The problem is mainly when the lap resumes a hibernated session, not when it starts as usual. If I try to diagnose the problem, some times it may connect and some times it may not and I need to restart the wifi router. I didn't tried the Auto tuning session, have to try when I reach home.
Old 11-28-2008
Brink
Let us know how it went MohanMathew.
Old 11-28-2008
mohanmathew
Ultimate32
At present my setting is like shown below screenshot.
I tried to change it, but it showing an error
How can I overcome this?
Old 11-28-2008
Brink
MohanMatthew,
You would just need to open a elevated command prompt instead from step 1. Right click on the Command Prompt shortcut and click on Run as administrator.
Old 11-28-2008
mohanmathew
Ultimate32
Yes, I changed it. Now the connection seems fast. I have noticed the wireless connection after hibernation, it was instant!!
Thank You soo much
Old 11-28-2008
Brink
You're welcome. I'm happy to hear that it is faster for you now.
Comment
Tutorial Tools
Tutorial Category
Problems with TCP Window Auto-Tuning since installing sp2 Vista General
TV Tuning Box Media Center
Vista Auto Tuning (Int. Adv. Users) Vista General
Receive Window Auto-Tuning on Vista Vista networking & sharing
Mic Volume Level Auto-Adjusts Vista music pictures video
