Vista - Visual Effects Options
Comment
Old 07-04-2007
Brink
How to Change the Visual Effects Options for Appearance and Performance in Vista
Old 08-14-2008
SIW2
VISTA HOME PREMIUM X64/ 7 x64 / 7x86
Re: Visual Effects Options
Hi Shawn,
Unless I missed it in the list of tutorials, there doesn't seem to be one explaining how to adjust processor scheduling for the best performance of programs using the advanced tab of performance options.
The Official Vista Magazine (UK ) recently recommended setting this to adjust for best performance of background services. The idea being that Vista switches between background service threads every 20ms or so when best performance is selected - using a lot of resources.
Trouble with that suggestion is that your foreground operations no longer get the priority boost.
A simple registry tweak allows the background services to enjoy a longer time between switches - thus saving resources, while also prioritising programs.
HKLM/SYSTEM/CurrentControlSet/Control/PriorityControl then set WiN32PrioritySeparation to 16 (hex).
A value of 14( hex) also gives this longer time between switches but adds no priority boost to programs.
SIW2
Old 08-14-2008
Brink
Interesting SIW2. I have done a little Googling in it, and this is what I found on it:
http://www.microsoft.com/technet/pro....mspx?mfr=true
Do you have a link to that article that you can post back or send to me via PM?
This tutorial explains a temporary way to set CPU priority.
CPU Priority for Processes
Thank you,
Old 08-22-2008
Starwing
Vista Home Premium
I have searched and there is so many places to look. I would like to know very simply, how to change the wording description under the icons on the desktop. Color mainly, but also is there a way to get the wording any size? Thanks.
Old 08-22-2008
Brink
Hi Starwing,
The only way to change the text size is to also increase the desktop icon size. The free program D-Color XP will let you change the text color though. It works fine in Vista.
Dindo Liboon's Website
Old 09-18-2008
Lightning Speed
Vista Ultimate x64
Nice guide thanks mate
Old 10-06-2008
Pharaoh
Vista Home Premium SP1 32-bit
Okay I have an issue similar to this. I turned off all the fade menus in / out options off. Then I decided to turn them back on however, they don't fade in or out, They slide. How do I make them fade again?
UPDATE:
Okay nevermind. I just did a system restore and it fixed it.
Old 10-19-2008
TorchMan
Vista Ultimate x64
Hello. I have did a little extension:
UN mark (disable) the option "Animate windows when minimizing and maximizing"
That's speeds the interface too.
Old 10-19-2008
Brink
Thank you TorchMan.
It has been added to the tutorial.
Old 05-18-2009
ilyabyk83
Microsoft Windows Vista Utimate x86
Hi. My screen looks a bit different. When I press "Settings" on Advanced tab of Performance, I have something what you have, and same goes for me. I don't see few items that you have on your shots.
Please help? I need to download something, maybe??
Old 05-18-2009
Brink
Hello Ilyabyk83,
The only one I spot that is missing is Enable transparent glass. This would be a feature of Aero. From the looks of your screenshots, I would say that you were using the Windows Basic theme instead of Windows Aero.
Double check in the yellow TIP box in the tutorial below to see if you meet the requirements to for Aero to be enabled.
Color Scheme
Comment
Tutorial Tools
Tutorial Category
Solved Visual Effects General Discussion
How can I set visual effects options under the restricted account? Vista General
Visual Effects Vista General
Visual Effects Options shortcuts? General Discussion
Removing Visual Effects Vista performance & maintenance
