Vista - Visual Effects Options
Comment
Old 07-04-2007
Brink
How to Change the Visual Effects Options for Appearance and Performance in Vista
Old 05-19-2009
ilyabyk83
Microsoft Windows Vista Utimate x86
Re: Visual Effects Options
Quote  Quote: Originally Posted by Brink View Post
Hello Ilyabyk83,
The only one I spot that is missing is Enable transparent glass. This would be a feature of Aero. From the looks of your screenshots, I would say that you were using the Windows Basic theme instead of Windows Aero.
Double check in the yellow TIP box in the tutorial below to see if you meet the requirements to for Aero to be enabled.
Color Scheme
Hi. Thank You!!! This is fixed now
Old 05-19-2009
Brink
You're welcome Ilyabyk83. I'm happy to hear that you got it sorted.
Old 05-25-2009
icynyx
Vista Home Premium x64 SP1
First off, i really liked this guide and it made my laptop a little bit faster. But I have a question, after changing the visual effects, I would sometimes notice that some of the visual effects that I have turned ON will turn off by itself. A good example is the Animate windows when minimizing and maximizing option, I like seeing the windows smoothly maximize and minimize, but it gets getting turned off, is there a way for this to stop?
PS. I have noticed that the visual effects aren't the only ones that gets turned off on its own. The option in the Windows Media Player to show your current playing song in MSN also gets ticked off from time to time. And I noticed that when something resets, the backup and restore center appears in my start menu.
Thanks.
Old 05-26-2009
Brink
Hello Icynyx, and welcome to Vista Forums.
Have you made any changes in the Ease of Access Center, just closed a game before the visual effects settings changed on you?
Old 05-26-2009
icynyx
Hi Brink,
I could never tell exactly when the changes occur, I'll just notice it when I maximize or minimize the windows; although, sometimes I'd see the blue circular picture right beside my mouse telling me its processing something, and then after I maximize or minimize a window I'll know that it's been changed again. (Then I look at my start menu, and I'll see that the backup and restore center icon is there even though I have never used it...)
I'm not positive of this, but I'm pretty sure I have not made any changes in the ease of access settings; however, I'll take a look at it when I get home today.
I've tried checking if it was a virus or spyware too. I've ran my Avast Anti-virus, Windows Defender, Windows MRT and I even went to kaspersky to run their online scanner, and none of them picks up anything...
Thanks for the reply,
icynyx
Old 05-26-2009
Brink
Icynyx,
I must admit that I'm not sure what may be causing this for you. As a test you might create a new administrator account to see if it still does it in that account.
Comment
Tutorial Tools
Tutorial Category
Solved Visual Effects General Discussion
How can I set visual effects options under the restricted account? Vista General
Visual Effects Vista General
Visual Effects Options shortcuts? General Discussion
Removing Visual Effects Vista performance & maintenance
