Disk Cleanup
How to Use Disk Cleanup in Vista
Disk Cleanup finds and then removes temporary files on your computer that you decide you no longer need to free up hard drive space.
For how to delete the Vista Temporary Files in Disk Cleanup that are less than a week old, see: How to Set Disk Cleanup to Delete Vista Temporary Files Less than a Week Old
Checking the Hibernation File Cleaner option to be deleted will disable the Hibernate and Hybrid sleep mode. If you did accidentally delete it, then see: How to Enable or Disable Hibernation in Vista
1. Open the Start Menu.​
A) Click on All Programs, Accessories, System Tools folder, and Disk Cleanup.​
B) Go to step 3.​
OR
2. Open the Start Menu.​
A) In the white line (Start Search) area, type Cleanmgr and press Enter.​
3. Choose if you want to clean files from just your user account or from all user accounts on the computer. (See screenshot below)​
NOTE: You will not see this window at all if you are running Disk Cleanup from the built-in Administrator account (How to Enable or Disable the Real Built-in Administrator Account in Vista). If you do not have the Files from all users on this computer option, then you are not running Disk Cleanup from within an administrator account. In an administrator account you will also need to make sure that you have UAC turned on to see it.
4. Select which drive you want to use Disk Cleanup on and click on OK. (See screenshot below)​
NOTE: You will not see this window unless you have more than one drive or partition on your computer.
5. If you chose Files from all users on this computer above, then click on Continue for UAC prompt.​
6. You will now see this screenshot below.​
7. When done loading, you will see either one of these screenshots depending on your choice. (See screenshots below)​
NOTE: If you just did a Upgrade install recently, then you will also see the Files discarded by Windows upgrade option. This would be for the C:\$INPLACE.~TR and C:\$WINDOWS.~Q folders. If you just did a Custom install recently, then you will also see the Previous Windows installations option. This would be for the C:\Windows.old folder.
8. Check the items you want to be deleted.​
NOTE: When you highlight a item, it will give you a description of what it is. You may also have the option to View Files to be deleted or set the Options for a item.
9. Click on OK.​
My files only ------------------------------------------ Files from all users
10. Click on Delete Files button on the confirmation prompt. (See screenshot below)​
11. Disk Cleanup will delete the files and close.​
12. For More Disk Cleanup Options -
NOTE: If you chose Files from all users on this computer (Step 3), then you will have a extra More Options tab. (See screenshot below)​
13. To Uninstall Programs in Program and Features -
A) Click the Clean up button under the Programs and Features section. (See screenshot below step 12)​
B) You will be taken to the "Uninstall or change a program" window in Programs and Features in the Control Panel.​
14. To Delete All but the Most Recent System Restore Point -
  • If you have the 64 bit Vista and have not already done this first, then you will need to do this correction and close and restart Disk Cleanup, see: How to Correct Disk Cleanup Shortcut for Vista 64 bit
  • If you have the Vista Enterprise, Ultimate, or Business edition, then all but the most recent Complete PC Backup will be deleted also if you selected the drive in step 5 that the Complete PC Backup is stored on.
A) Click the Clean up button under System Restore and Shadow Copies. (See screenshot below step 12)​
B) Click on Delete to confirm deleting all but the most recent system restore point. (See screenshot below)​
NOTE: If you want to delete all system restore points, then turn System Restore Off and then back On to reset it. See: How to Turn System Restore On or Off in Vista
There's also a way to set up a batch file to run this. First you need to go to Start -> Run and then type in CleanMgr /sageset:99 (where 99 is just a reference number to refer to your configuration of CleanMgr when you run the batch file). When you hit enter, the Disk Cleanup window will pop up (shown in step #7 above). You can change to configuration and then click ok. After that, create a text file with the following in it:
cleanmgr /sagerun:99
exit
Save that text file as <filename>.bat and put it in a folder that you use for admin tasks (e.g. Documents\Admin\). Then go to your Task Scheduler and set this up to run whenever you want. You can also add other tasks to run in the batch (.bat) file, like copying or deleting temp files or folders, etc.
Thanks for the reminder on this.
Digibean,
Welcome to the forum and thank you for this tip.
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
Thank you very much for this guide. Appreciates much! ^^
    Dell****
    2.13Ghz Core2Duo
    2GB
    GeForce 9500GT
    Dell****
    Dell****
    1280x960
    Dell****
    Razer Diamondback
    Over 9000 Mbps
Your welcome Arakai.
I do not get:
I saw "NOTE: You will not see this window unless you have more than one drive or partition on your computer." but I have multiple drives on my computer.
    Self built
    Intel E8400 3GHz
    Intel DX48BT2
    Kingston PC3-10666 4Gb
    XFX 9800 GTX XXX
    Soundblaster X-Fi XtremeMusic
    2x Samsung SM-T220HD 22"
    1680x1050 on two monitors
    WD Raptor X/150Gb in RAID0
    WD Raptor 36gb
    3x Samsung F1 1Tb
    Thermaltake ToughPower 850w
    Thermaltake Armor
    Tuniq Tower 120
    Dell Multimedia Enhanced USB
    Razer Diamondback 3G
    Thermaltake Muse esata caddy
Hi Swarfega,
For this, you will need to be running Disk Cleanup from within an administrator account and have UAC turned on. The NOTE is only for the screenshot under step 5.
yeah I have full admin account since I followed the tut on here and uac is on
    Self built
    Intel E8400 3GHz
    Intel DX48BT2
    XFX 9800 GTX XXX
    WD Raptor 36gb
    3x Samsung F1 1Tb
    Thermaltake Armor
    Tuniq Tower 120
Ok, I see now Swarfega. You will not see that screen when running Disk Cleanup from within the built-in Administrator account.
ah ok, thanks.
    Self built
    Intel E8400 3GHz
    Intel DX48BT2
    XFX 9800 GTX XXX
    WD Raptor 36gb
    3x Samsung F1 1Tb
    Thermaltake Armor
    Tuniq Tower 120
Your welcome Swarfega.
Hi Shawn, nice tutorial but there's an easy way to access disk cleanup,
Click start>run and type cleanmgr and press enter.
    Intel Dual Core 3 GHz
    3 GB DDR 2 667 Mhz
    ATI X1550 256 MB
    Samsung 19"
    80 GB IDE Samsung.
    iBall
    iBall
    2mbps
Hello Kavita,
Yes, that was already there as step 2, but I cleaned it up a bit more to make it stand out better. ;)
Thank you,
Thanks alot Shawn :)
DD
    HP dv6000 CTO Entertainment Lappy :D
    Intel Core 2 Duo T8300 @ 2.4GHz (2 CPUS), ~2.4 GHz
    4094 MB Ram
    NVIDIA GeForce 8400M GS, 2031 MB Memory
    Realtek Hi-Def Sound Card
    Generic PnP Monitor
    1200x800
    HP Laptop :D
    Fans
    Laptop
    Microsoft Pro Mouse :D
    DL: 20.51 Mb/s, Up-Load :5.27 Mb/s Ping: 10 ms
You're welcome DarkDavil. :)
:Dhello brink just wnna know which files should be deleted. when I opened the disk clean up only 3 files that has a check . the rest of the files are uncheck
recycle bin 0 bytes
set up log files 108 kb
system error memory dump files 231 mb
system error minidump files 346 kb
thumbnails 1.00 mb
per use archived windows error report...479 kb
system archived window error report... 83.0 kb
should I delete this file? I did not include hibernation file cleaner coz I know that it should not be deleted when Im using the hibernate thing
Hello Dylana,
You can check all of them, except Hibernation File since you are using Hibernate, to be deleted if you would like to. It will not hurt anything since they are just junk files. :)
You're welcome Dylana. :)
