| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | System Restore - disk space How to Change the System Restore Disk Space Usage Amount in Vista |
| 32bit | Re: System Restore - disk space Wow how much total disk space do you have? Why would you spend 137GB on system restore alone? Even 30 GB is too big i think.. I reduce mine to 3 extent it to 5 recently... |
| Vista Ultimate x64 | Re: System Restore - disk space Hi, First of all this thread has helped a lot. I have been able to set my Max Shadow Storage to 50GB from about 112GB (My HDD 75ogb) Anyways... now that I have set my max to 50gb (which I did a few weeks ago)... my used and allocated space is now larger than the max? Used: 57+GB Allocated: 59+GB Max: 50GB Why is it like this? :/ Any help is appreciated, thanx. Last edited by yvescy; 07-31-2009 at 03:03 AM.. Reason: added |
| Vista home premium 32bit | Re: System Restore - disk space Djlevel9, I would not "fix" anything. The more restore points you have, the safer you are. And since you have an abundance of disk space, the 68GBs should not put you into a bind. That will give you restore points for about 6 weeks back (depending on the number of installs). |
| Vista Home Premium | Re: System Restore - disk space This worked like a charm! Dropping by to say thanks! |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: System Restore - disk space You're welcome IvyGold. I'm happy to hear that you got it sorted. |
| Tutorial Tools | |
| Tutorial | Category | |||
Managing System Restore Disk Space Usage | General Discussion | |||
| Local Disk/System Restore/"eating" up space | General Discussion | |||
| disk space Vs restore points | Vista performance & maintenance | |||
| How To: Reduce Disk Space Used By Windows Vista System Restore | Vista General | |||
| System Restore increase disk space used | Vista General | |||
