Vista - System Restore - disk space
Comment
Old 05-30-2007
Brink
How to Change the System Restore Disk Space Usage Amount in Vista
Old 07-10-2008
Brink
Re: System Restore - disk space
Hi eejit, and welcome to Vista Forums.
Check to make sure that you have System Restore turned on and that these Services set as:
Volume Shadow Copy
This service is set to Started and Manual by default.
Microsoft Shadow Copy Provider
For how if needed, see: How to Disable or Enable Vista Services with an Advice Guide
Old 07-11-2008
eejit
Vista Home Premium x32
Brilliant thanks worked perfectly, best tech website i have ever seen!
Old 07-11-2008
Brink
Your welcome eejit.
Old 07-14-2008
nipo
32
I tried to change partition like this: vssadmin Resize Shadow Storage /For=C: /On=D: /Maxsize=5GB, but system does not allowed me to select another partition, but just C.
So, how can I set another partition (exp. D:\ for shadow files for Restore points?
Another questions, I have back up entire system and I like it restore just Restore points?
How Can I do that?
What’s the name of restore ponts on disk and where is location?
Tx
Old 07-14-2008
Brink
Hello Nipo, and welcome to Vista Forums.
Step 6A in this tutorial will show you how to select another driver letter to be used for restore points instead.
System Restore
Old 07-21-2008
heph
vista business
Hi Shawn
Please help with my disk space problem. I have tried to resize the space for the restor epoints but still I am not getting the solution out of the hard disk problem.
Thanks, heph
Old 07-21-2008
Brink
Hi Heph,
What is the problem that you are having with your hard drive?
Old 07-21-2008
heph
vista business
Hi Shawn,
I have lenovo R61 with vista installed. When I run windirstat on drive C, the total space on c is 67.9GB but then windirstat indicates that 44.3GB is unknown.
thxs, heph
Old 07-21-2008
heph
vista business
Hi Shawn,
The hard disk is filled up with I do not know what yet I have not installed many programs on it. I try to store my data on an external hard disk up I keep getting all these messages that my disk space on C is used up.
Thxs, Heph
Old 07-21-2008
Brink
Heph,
I found this about a feature called ThinkVantage that may be what is using the space. I'm not sure how it works, but your computers' documentation should help explain it and hopefully how to disable it.
Lenovo - Innovation - Rescue and Recovery
Comment
Tutorial Tools
Tutorial Category
Solved Managing System Restore Disk Space Usage General Discussion
Local Disk/System Restore/"eating" up space General Discussion
disk space Vs restore points Vista performance & maintenance
How To: Reduce Disk Space Used By Windows Vista System Restore Vista General
System Restore increase disk space used Vista General
