How to Change the System Restore Disk Space Usage Amount in Vista
Hi Alan,
Yes thank you, that had been updated in the tutorial itself to make that point more clear.![]()
How do I change the allocated shadow copy storage space?
It keeps deleting my restore points or only saving them on the D drive where I can't get to them.
Hello Rawbery,
The Allocated Shadow Copy Storage space is controlled by Vista as it is needed for restore points and shadow copy. It is limited to the Maximum Shadow Copy Storage space size you set. Increasing the max size will eventually lead to a larger allocated size if Vista needs the space.
In this tutorial, check to make sure that only the C: (System) drive is checked with Vista on it to have restore points only for it.
If you dual boot with XP, then this tutorial can help stop XP from deleting you Vista restore points whenever you startup XP.
Hello Shawn !
I have three drives: C:, D:, E: on my computer. I turned on the System Restore for the C: and E drive.
I used the vssadmin list shadowstorage cmd above and it shows all three drives' Allocated System Restore Size while only two are selected, any reason why? Would you recommend setting SR on all three drives ?
Also, my System Restore only saves points for 1 day period. Do I have an option to extend the time it stores information in case I want to restore back to a few days instead of one?
Thanks.
Hello Bennys,
I'm not sure why all 3 drive letters would show up unless you had them checked in System Protection.
I would only recommend having System Restore turned on for all three if you want or need to do a System Restore for them at some point.
You can adjust the settings for the System Restore task to how often you want restore points to be automatically created.
System Restore Task - Change Automatic Restore Point Schedule
Of course, you can manually create a restore point anytime you like.
Thanks Shawn.
As stated in this tutorial "By default Vista allocates 15% of your selected hard drive volume", however; it does not apply when I extended the volume space, must I manually make the change to 15% of my current volume size?
Now you tell me.Great advice is now heeded.
I just performed a Complete PC Backup and since I'm in a learning mode, I'll be doing quite a few changes to the computer so mistakes are expected. If, I somewhere down the line, choose to do another Complete PC Backup to the same drive, must I delete the old one first or will it automatically be overridden?
Just out of curiousity, why don't I see anyone restoring their E: drive? Is it already set as a default by the manufacturer?
Thanks.
Q1) You would only need to change the system restore disk space if you wanted it larger or smaller.
Q2) No need to delete the old Complete PC Backup. When you create a new one to be saved on the same drive, it will do a incremental backup of only what has changed since the last Complete PC Backup.
Q3) Usually people only have their C: system drive with Vista on it set for restore points to be created for. Unless they have something on a E: drive that they need or want restore points for, it would be a waste of disk space.
Thanks Shawn.
My E: drive has11.4 GB and initially, it was almost completely empty until I turned its System Restore on. Now, it's gradually depleting the drive space. My yearning inquiries are(has always been):
1. O.K...what is on my E: drive anyway?
2. What is it backing up when it is not even being used. Furthermore, Vista has set the system drive(C: ) as the SR default.
By setting a SR for it, how does it affect my disk space? I didn't notice any change in both C: and D: drive.
Thanks again.
thanks Brink, worked perfectly...gained ~70GB of overused shadowcopy space...
You're welcome AcidBurn.
| Similar Threads | ||||
| Tutorial | Tutorial Starter | Category | Comments | Last Post |
Managing System Restore Disk Space Usage | 5er driver | General Discussion | 1 | 05 Mar 2009 |
| Local Disk/System Restore/"eating" up space | Mike92 | General Discussion | 3 | 06 Jan 2009 |
| disk space Vs restore points | t-4-2 | Vista performance & maintenance | 5 | 21 Apr 2008 |
| How To: Reduce Disk Space Used By Windows Vista System Restore | Former captain of the Enterprise | Vista General | 2 | 24 Apr 2007 |
| System Restore increase disk space used | Bronskimac | Vista General | 0 | 17 Jun 2006 |
