RB
Vista - System Restore Point - create
Comment
How to Create a System Restore Point in Vista
Published by Brink
07-09-2007
Information
System Restore will normally automatically create a restore point at various times. By default restore points are created once per day at 12 AM and at startup in Task Scheduler, and before significant system events such as program or driver installation. To change this task schedule, see: How to Change the Automatic System Restore Point Settings in Vista Task Scheduler .You can also manually create a restore point anytime you want to.
Tip
This can be helpful if you would like to create a restore point before doing any important or experimental change to your system. For example, installing something risky.
Note
System Restore uses the Volume Shadow Copy service with the default setting of Manual. To change this, see: How to Disable or Enable Vista Services With a Advice Guide
Warning
RELATED LINKS:
1. Open the Start Menu.
2. In the white line (Start Search) area, type SystemPropertiesProtection.exe and press Enter.
NOTE: You can also click on All Programs > Accessories > System Tools > System Restore in the Start Menu.
3. If prompted, click on Continue in the UAC prompt.
4. Click on the Click to Play button in the video below.
Published by
Brink's Avatar
Administrator
Brink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond repute
Tutorial Tools
Applies to
All Vista Versions
64 Bit & 32 Bit
12-07-2007
niGht kiD
Vista™ Business 32-bit
Re: System Restore Point - create
Hi Shawn,
Let's say if I've created 5 restore points, is there any way to choose which restore point to delete? As far as I know Disk Cleanup can only remove all but the most recent restore point.
12-07-2007
Brink
niGht kiD,
Not that I'm aware of. You can delete all of them by turning System Restore off and then back on, or use Disk Cleanup for all but the most recent one.
Sorry,
07-21-2008
Hogtowner
Vista Ultimate x64 SP2
Lightbulb Re: System Restore Point - create
I'd like to point out that there is a scheduled service called SR that creates system restore points for you. By default (at least in Ultimate 64x SP1) the service is scheduled to create a restore point each time you boot up.
If you are like me, and likely to run your machine for weeks at a time without rebooting, you might find that you want more restore points set. Also having the restore point created on reboot adds another 3 minutes (on my system) to that sluggish response time on startup. I have my machine set up now to create a restore point every night at 4:00am, before ritual rootkit scans and backups.
It is fairly easy to edit the trigger for SR inside the Task Scheduler. Perhaps a tutorial on that would be appreciated?
07-21-2008
Brink
Not a bad idea Hogtowner. I'll make one tonight about it and postback the link for it.
Thank you for the suggestion,
07-22-2008
Brink
Ok Hogtowner, here is the link for the suggested tutorial.
System Restore Task - Change Automatic Restore Point Schedule
How does it look to you?
07-25-2008
Hogtowner
Looks great, Shawn. You are nothing if not thorough.
I must have overestimated interest in it though, judging by the number of views.
07-25-2008
Brink
I can see how it can be handy if one wanted to use System Restore, but not have as many automatic restore points created or change when they are created.
It should pick up though. Thank you for the suggesting it.
09-21-2008
f_voragen
Vista Home Premium 32bit.
Hello Shawn (Brink)
So let me see if I got this all right?
1) we can use the vssadmin tool to set the size of the shadowstorage area
2) we can use your two downloads to turn on/off SR when installing updates
3) we can control auto daily and startup SR creation
I ask this because I had a situation where the shadow area was 30GB it was full, there were only 25 restore points in there? 30G/25>1G. I thought SR only needed 300M to function. My HDD is 250GB so the 30GB is not the problem, its the 25 RPs
secondly 7 of those RPs were due to microsoft updates on one day, 5 more from microsoft the day before all while I'm trying to load a batch of software myself that requires many restarts. All in all what I ended up with was 25 RPs covering 3.5 days, using 30GB on a 250GB drive, somethings not right?
What I need is... 1 RP per day at startup for a month in as little space as possible
Can you help
F W. Voragen
Newbee.
09-21-2008
Brink
Hi F W. Voragen,
You might see if also doing this tutorial can help.
System Restore Point - Disable for Device Driver Install
The only problem with turning System Restore off is that it also deletes all restore points. You could reduce the size of the storage area for System Restore, but it will not change them from being created. It will just not have as many restore points stored instead.
Restore points are stored for up to 90 days or until there is no more space, then the older ones get deleted as new ones are added. About the only thing you can do is to delete all but the most recent one manually each month using Disk Cleanup.
Comment
RB
Tutorial Tools
Similar Threads for: System Restore Point - create
Tutorial Category
unable to create system restore point Vista General
Cannot Create System Restore Point (0x80042318) Vista performance & maintenance
System Restore error (create restore point), event ID: 8193 Vista General
Couldn't create a system restore point in Vista General Discussion
failed to create system restore point Vista security
