Vista Tutorial - System Restore - How to
Comment
Old 07-11-2007
Brink
Administrator
How to Do a System Restore in Vista
Old 09-23-2008
sakala
Newbie
Vista Home Premium 32bit
Re: System Restore - How to
I am in an urgent need to get it explained how to make a restore when you are not able to get to Windows.
My Vista worked fine untill couple of days ago and I am unable to start it. When tried to boot it in the safe mode I noticed it stopped when loading CRCDISK.SYS and then just tries to reboot.
Dell Support is claiming I could make a repair by using virtual partition X and Vista Disc. When I tried I couldn't find an OS to choose so I should choose installation file manually.
As that part is new to me and as i am not finding any installation file to select and make a repair I need help.
Please advise.
Old 09-23-2008
Brink
Administrator
Hello Sakala, and welcome to Vista Forums.
You could use Option One in this tutorial below to create a Recovery Disc that you can use to do a System Restore at boot (Method Two) here with.
Create a Recovery Disc
Old 09-24-2008
sakala
Newbie
Thank you.
I will try and get back.
Old 09-24-2008
sakala
Newbie
I managed to run Startup repair but I am now only getting black screen with the pointer on.
It seems that The repair repaired the disc that had some king of "bad volume information that was damaged.
Is there any way to repair even this part?
The PC is pretty new (since June). Should I ask Dell to replace it or is there a workaround?
Thanks in advance.
Old 09-24-2008
Brink
Administrator
Sakala,
I would say go ahead and do a clean reinstall of Vista since it still did not help.
Old 09-25-2008
sakala
Newbie
Thanks
Old 09-25-2008
Brink
Administrator
Your welcome Sakala.
Unread 2 Hours Ago
littlestep
Newbie
vista
Unhappy Re: System Restore - How to
hi err im having an issue with my comp it keeps giving me a blue screen and tells me to run it in safe mode which ive tried but it didnt work and ive done all the other options it listed but none of em worked x.x. i tried to do a system restore like u said but when i clicked on system restore and then create a restore point it wouldnt let me =/. any help would be greatly appreciated >.<.
Unread 14 Minutes Ago
Brink
Administrator
Hello Lettlestep, and welcome to Vista Forums.
Well, other than a clean reinstall of Vista, you might see if you may be able to a repair install.
Comment
« New Folder | - »
Tutorial Tools
Tutorial Category
System Restore Task - Change Automatic Restore Point Schedule Tutorials
System Restore error (create restore point), event ID: 8193 Vista General
System Restore: do restore points persist after a restore? Vista General
System restore hasn't held a restore point since I installed Vista Vista General
system restore not creating system restore everyday Vista General
