| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Start Menu - Pin to How to Pin a Program to the Start Menu in Vista Last edited by Brink; 04-30-2009 at 12:58 PM.. |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Start Menu - Pin to A pinned item is a shortcut. It does not copy the exe file, but is only a shorcut file that merely points to the exe file like a shortcut does. |
| Tutorial Tools | |
| Tutorial | Category | |||
| Start Menu - Enable or Disable Pin to Start Menu | Tutorials | |||
| Lock Button on Start Menu will not show Menu | Vista General | |||
| START MENU RIGHT PANE LINK OR MENU OPTION | Vista General | |||
| Default Start Menu option missing from Taskbar & Start Menu properties screen | Vista General | |||
| TRANSPARENT GLASS MENU IN CLASSIC WINDOWS START MENU | Vista General | |||
