Vista - Speed Up the Performance of Vista
Comment
Old 07-29-2007
Brink
How to Speed Up the Performance of Vista
Old 11-28-2008
Brink
Re: Speed Up the Performance of Vista
You're welcome Kevin.
Old 12-03-2008
Geekpower2000
Vista Home Premium 32bit
Yeeeeeessssss. This information should be highly useful. Thank you, sir.
Old 12-03-2008
Brink
You're welcome Geekpower2000.
Old 12-05-2008
antonyua
Microsoft® Windows Vista™ 32bit
Talking Re: Speed Up the Performance of Vista
Sorry for so Many Questions that i make
But I Really Like you Forum And Want to learn More things
So Here Is another one Question
Quote:
2. Install the Latest BIOS and Device Drivers
Make sure that you have the latest drivers installed for all of your devices and BIOS version for your motherboard. Check at the device's website for them. Be sure to have the correct versions for your 32 bit or 64 bit Vista.
Where can i Find About my Bios Version ... and If It Is Up to Date
Ok i found my Version Of bios but dont know if its need update :P still looking
" Phoenix ROM BIOS PLUS Version 1.10 A07 "
Ok I Found a program that scaned my bios and drivers for updates... and here are the results
http://biosagentplus.com/results.php?ref=49ljgxw&referral=302
but i cant update them..
is there a similar program that does this scan and updates also or a site when can i download a bios update ???
Old 12-05-2008
Brink
No problem Antonyua,
I would not flash you BIOS unless you needed the addressed issues listed in the newer BIOS release notes.
What is your motherboard brand and model number? I would recommend to always get the BIOS from the motherboard's manufacturer website.
Old 12-05-2008
antonyua
Manufacturer : Dell Inc
Model : 0xr509
Chipset : intel pm965 Rev. : c0
Ok got It ... I Searched Dell Site and downloaded Some Drivers for my lap
Old 12-05-2008
Brink
Ok. Glad you got it sorted.
Old 12-06-2008
JohnVanNgo
Vista Ultamate 32Bit
Wow! awesome list brink! serously boosted my system. SO dlad I registered.
Old 12-06-2008
Brink
Glad to have you aboard John.
Thank you,
Old 12-15-2008
Monsta
Vista Ultimate x86
I am new to the forum and a new user to Vista. I'd just like to congratulate you on a fantastic forum. Keep up the good work.
Thank you.
Comment
Tutorial Tools
Tutorial Category
How to test USB speed / performance Vista hardware & devices
Oblivion and Vista Speed/Performance :: Help Needed Vista Games
speed and performance information Vista performance & maintenance
Using a Flash USB thumb drive to speed up performance? Vista installation & setup
ReadyBoost, Speed up your PC’s performance Vista General
