Vista - Speed Up the Performance of Vista
Comment
Old 07-29-2007
Brink
How to Speed Up the Performance of Vista
Old 02-03-2009
Brink
Re: Speed Up the Performance of Vista
Agreed. Thank you MilesAhead.
It has been removed.
Old 02-11-2009
kaizermeow
vista 32
i have a windows vista 32-bit home premium, the problem is that the boot up screen takes too long, the scrolling bar moves 24 times along, compared to a safe mode boot which only takes about 14 scrolls. what could be my problem?
Old 02-11-2009
MilesAhead
Vista Home Premium 64 bit SP1
In the start menu search type msconfig and hit enter.
In the Boot tab check the box for Boot Logging.
After you reboot search the Windows directory for
ntbootlog.txt
You can look at it in notepad. You'll probably see a whole bunch of lines like
failed to load driver c:\xxxxx\xxxx.sys
You have to find out what the drivers go to. It may be stuff
that's no longer on your system. If your machine came with Norton
stuff, and you uninstalled it manually or using de-crapifier type program
you will probably need to download the Norton Removal Tool and run it.
Google on the driver filenames before you do anything. Also it's a good
idea to make a restore point and if you have an image backup program,
back up your system in case it gets muddle to where it won't boot at all.
If you find out more and it's not obvious what to do, post again.
Before messing around too much make sure you have a way of
restoring your system to at least get back to where it is now.
Old 02-13-2009
Ali Abou
Vista Home Basic 32bit.
Thanks', that was fine information.
Old 02-13-2009
Brink
You're welcome Ali Abou, and welcome to Vista Forums.
Old 02-23-2009
dr_sdaa7
Vista Home Premium 32bit
hi Brink
really u r a genius
i have been using vista since year and half . and really today was the best performance i had since doing all the steps u posted ... thanks allot ... really u
r great ..
may i ask u 2 questions ..
1- there is only a problem in my pc .. i use a encoding program , easy real media .and
when it works it takes maybe an hour to finish a task .. my problem that while its working my pc hangs and stuck like it is heavy ... really heavy .what do u suggests ?
2- can i translate this post to arabic and refers 2 u ? coz i bet that whatever there is
posts .. this is the best .... and i wish to share it with friends .. thanks
Old 02-23-2009
Brink
Hello Dr_Sdaa7,
I would recommend to use another program or see about increasing the horsepower of your system if it is needed.
Yes, you can translate this tutorial as long as it is not translated into English and that it is linked back to this tutorial.
Old 04-02-2009
superneat
truly helpful
Old 04-12-2009
brummyfan
Vista Home Premium SP2 32bit, Windows7x32bit
Hi Shawn,
I have reduced the system restore disk space from 15GB to 3GB with:
System Restore - disk space
It really made my laptop very fast indeed, pages load almost instantly. I am sure you would already have known about this but just wanted to share my experience with you. Thank you for all your hard work.
Old 04-12-2009
Brink
Thank you Brummy.
Comment
Tutorial Tools
Tutorial Category
How to test USB speed / performance Vista hardware & devices
Oblivion and Vista Speed/Performance :: Help Needed Vista Games
speed and performance information Vista performance & maintenance
Using a Flash USB thumb drive to speed up performance? Vista installation & setup
ReadyBoost, Speed up your PC’s performance Vista General
