| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Speed Up the Performance of Vista How to Speed Up the Performance of Vista Last edited by Brink; 05-03-2009 at 03:35 AM.. |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Speed Up the Performance of Vista Since it was the older free version, it is fine FLE. |
| Vista Home Premium 32bit | Re: Speed Up the Performance of Vista OK, I'll do that. I have a question regarding defrag. On my pc, drive "c" which has a recovery partition drive "d" and Auslogics tells me it is 35% fragmented, I am unable to defrag the partition; it always shows the same fragmentation before and after. Is it not possible to do that? |
| Vista Home Premium x64 | Re: Speed Up the Performance of Vista OMG thank you sooo much I was praying that I did not get banned for that last post as I do visist here often I really like it here. |
| Vista Home Premium 32bit | Re: Speed Up the Performance of Vista |
| Vista Home Premium x64 | Re: Speed Up the Performance of Vista Cool tnx for the post hdbg62 |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Speed Up the Performance of Vista OK, I'll do that. I have a question regarding defrag. On my pc, drive "c" which has a recovery partition drive "d" and Auslogics tells me it is 35% fragmented, I am unable to defrag the partition; it always shows the same fragmentation before and after. Is it not possible to do that? |
| Vista Home Premium 32bit | Re: Speed Up the Performance of Vista 36. Change the Number of Processors Used at Boot-Up in Vista This is done automatically, even though it is not set so. |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Speed Up the Performance of Vista Yep, that is stated in that tutorial. ![]() Thank you. |
| Vista Ultimate x64 | Re: Speed Up the Performance of Vista nice one, simple yet so good, after only doing a few of the things you said my Pc is running much faster. It's a very big thanks from me. |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Speed Up the Performance of Vista You're most welcome John. |
| Tutorial Tools | |
| Tutorial | Category | |||
| How to test USB speed / performance | Vista hardware & devices | |||
| Oblivion and Vista Speed/Performance :: Help Needed | Vista Games | |||
| speed and performance information | Vista performance & maintenance | |||
| Using a Flash USB thumb drive to speed up performance? | Vista installation & setup | |||
| ReadyBoost, Speed up your PC’s performance | Vista General | |||
