Vista - Speed Up the Performance of Vista
Comment
Old 07-29-2007
Brink
How to Speed Up the Performance of Vista
Old 05-24-2009
DarkDavil
Vista Home Premium x64
Re: Speed Up the Performance of Vista
Jee thanks man! I registered to this forum after using many of your tips on here and my vista x64 is rocking now! Much faster boot/ many applications load times! Thanks!
Old 05-24-2009
Brink
You're welcome Dark Davil, and welcome to Vista Forums.
Old 05-28-2009
sumitdutta
Vista ultimate exreme 32bit
that was awesome man
Old 05-28-2009
Brink
You're welcome Sumitdutta.
Old 05-28-2009
rai
Vista Home Premium 32bit
Its a great tutorial, really helpful. This site was 100% recommended. Now I'm beginning to like my vista computer than my old XP system.
Old 05-28-2009
Brink
You're welcome Rai, and welcome to Vista Forums.
Thank you,
Old 05-31-2009
Nominativ
Vista Ultimate x64
I'll try this tomorrow, thanks
Old 05-31-2009
Brink
You're welcome Nominativ. Please let us know how it went for you.
Old 06-14-2009
Blaqkie
Vista Home Premium 64bit
Ok, I don't know what's going on but Vista this shouldn't be happening. I did quite about half of all your Vista performance tricks, and didn't want to complete others because of other reasons. Vista has improved, boot up is faster, shutdown is better, and overall my computer functions better. However, my computer's CPU and RAM usage is working 2x as much as it was before I did those little tricks. What's going on? iTunes, Firefox, and mIRC run at about 3% idle now, vs. the 1% idle I have had for the past month. When I first boot up and log in, my RAM usage is at 21% vs. the 24% I used to have. However, now RAM usage is going up a lot, lot faster. In just 5 minutes, doing anything, even just opening a folder, then my RAM usage will shoot up to 28%. Right now my RAM usage is at 47% and my computer has been on for 40 minutes. The highest my RAM usage has ever been before I did your performance helper tutorial was 34%. Can you explain what's happening?
Old 06-14-2009
Brink
Hello Blaqkie, and welcome to Vista Forums.
I'm not sure what may be causing this since none of the tips should cause this. You might look in Resource Monitor to see what specifcally may be using this much of your resources.
You can also try a System Restore using a restore point dated before you had this high usage to see if it can help.
Comment
Tutorial Tools
Tutorial Category
How to test USB speed / performance Vista hardware & devices
Oblivion and Vista Speed/Performance :: Help Needed Vista Games
speed and performance information Vista performance & maintenance
Using a Flash USB thumb drive to speed up performance? Vista installation & setup
ReadyBoost, Speed up your PC’s performance Vista General
