Vista - Speed Up the Performance of Vista
Comment
Old 07-29-2007
Brink
How to Speed Up the Performance of Vista
Old 06-14-2009
Blaqkie
Vista Home Premium 64bit
Re: Speed Up the Performance of Vista
Alright. Thank you for the quick answer. I'll take a look at the resource monitor. But I won't be able to do a System Restore since part of your tutorial was deleting all but the most recent ones.
Old 07-02-2009
shortmantuff
Vista Home Premium 32bit
Is SP1 better than SP2 and SP3? Is that why you say install SP1?
Old 07-02-2009
Brink
Hello Shortmanstuff,
While installing any service pack can help fix bugs and improve performance in Vista, SP1 is required to be installed before SP2 can be installed. That's all.
There is not a Vista SP3 yet though.
Old 07-02-2009
shortmantuff
Okay. I have SP2 so it must have installed SP1 prior to that then.
Only 2 service packs. Pshhh, Microsoft better get on top of that
Old 07-03-2009
Brink
LOL, yep if you have SP2, then SP1 is already installed.
Old 07-17-2009
smartsujiki
Vista Home Premium x64
very informative post.....thanx ... will definitely try these changes
Old 07-17-2009
Brink
You're welcome Smartsujiki, and welcome to Vista Forums.
Old 07-17-2009
sroblesc64
home premium vista 64
Brink:
I posted some info in some other tag after trying out tutorial on performance (reducing boot time), but this is where I'm right now where event log reports:
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
<Provider Name="Microsoft-Windows-Diagnostics-Performance" Guid="{cfc18ec0-96b1-4eba-961b-622caee05b0a}" />
<EventID>100</EventID>
<Version>1</Version>
<Level>1</Level>
<Task>4002</Task>
<Opcode>34</Opcode>
<Keywords>0x8000000000010000</Keywords>
<TimeCreated SystemTime="2009-07-17T15:08:54.061Z" />
<EventRecordID>474</EventRecordID>
<Correlation ActivityID="{00000001-0000-0000-747C-EF20F006CA01}" />
<Execution ProcessID="1888" ThreadID="2156" />
<Channel>Microsoft-Windows-Diagnostics-Performance/Operational</Channel>
<Computer>XXXXXX-PC</Computer>
<Security UserID="X-X-X-XX" />
</System>
- <EventData>
<Data Name="BootTsVersion">2</Data>
<Data Name="BootStartTime">2009-07-17T15:06:14.796Z</Data>
<Data Name="BootEndTime">2009-07-17T15:08:49.631Z</Data>
<Data Name="SystemBootInstance">81</Data>
<Data Name="UserBootInstance">69</Data>
<Data Name="BootTime">114298</Data>
<Data Name="MainPathBootTime">46898</Data>
<Data Name="BootKernelInitTime">25</Data>
<Data Name="BootDriverInitTime">2566</Data>
<Data Name="BootDevicesInitTime">7823</Data>
<Data Name="BootPrefetchInitTime">59010</Data>
<Data Name="BootPrefetchBytes">597319680</Data>
<Data Name="BootAutoChkTime">0</Data>
<Data Name="BootSmssInitTime">10936</Data>
<Data Name="BootCriticalServicesInitTime">12620</Data>
<Data Name="BootUserProfileProcessingTime">4793</Data>
<Data Name="BootMachineProfileProcessingTime">3602</Data>
<Data Name="BootExplorerInitTime">7116</Data>
<Data Name="BootNumStartupApps">2</Data>
<Data Name="BootPostBootTime">67400</Data>
<Data Name="BootIsRebootAfterInstall">false</Data>
<Data Name="BootRootCauseStepImprovementBits">0</Data>
<Data Name="BootRootCauseGradualImprovementBits">0</Data>
<Data Name="BootRootCauseStepDegradationBits">0</Data>
<Data Name="BootRootCauseGradualDegradationBits">0</Data>
<Data Name="BootIsDegradation">false</Data>
<Data Name="BootIsStepDegradation">false</Data>
<Data Name="BootIsGradualDegradation">false</Data>
<Data Name="BootImprovementDelta">0</Data>
<Data Name="BootDegradationDelta">0</Data>
<Data Name="BootIsRootCauseIdentified">false</Data>
</EventData>
</Event>
Other event ID's 100, 200,201
How can I fix this?
tks
Old 07-17-2009
Brink
Hello Sroblesc, and welcome to Vista Forums.
I'm not certain what the problem is, but you can see if doing a System Restore using a restore point dated before this problem may be able to fix it for you.
Old 07-21-2009
Random
Do you consider making a similar setup for Windows 7? Although it is fast to start with, faster is always better! =)
Comment
Tutorial Tools
Tutorial Category
How to test USB speed / performance Vista hardware & devices
Oblivion and Vista Speed/Performance :: Help Needed Vista Games
speed and performance information Vista performance & maintenance
Using a Flash USB thumb drive to speed up performance? Vista installation & setup
ReadyBoost, Speed up your PC’s performance Vista General
