| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Speed Up the Performance of Vista How to Speed Up the Performance of Vista Last edited by Brink; 05-03-2009 at 03:35 AM.. |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Speed Up the Performance of Vista Amplid, You can see where to download the standalone SP1 installer here, but be sure to read the top link on why you might not see the SP1 in Windows Update to make sure that it does not apply to you to avoid any potential problems during installation. Why SP1 may not be available for you and how to get it As usual, be sure to backup anything you do not want to lose before installing the SP1 to be safe. Shawn |
| Vista Ultimate x64 | Re: Speed Up the Performance of Vista Brink I have a question about the driver of one of my devices. I ran this sort of scanner to see which device drivers were out of date and it said that my 'NVIDIA N-Force PCI System Management' driver was. So I tried to find one at www.nividia.com, but you get a whole bunch of types of this device and I don't know which one mine is. Any suggestions? Thanks for the tips, helped a lot! 26 is indeed important ![]() Amplid |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Speed Up the Performance of Vista Amplid, I'm not sure, but I believe if you just have the latest 169.25 or 169.44 Beta driver version you should be ok. You might post this in the Drivers forum to see if anyone else may know more on this to. NVIDIA Driver Downloads - Advanced Search Shawn |
| Vista Ultimate x64 | Re: Speed Up the Performance of Vista Ok, thanks Shawn, I'll try posting it there. Amplid |
| Vista Home Basic 32bit | Re: Speed Up the Performance of Vista Good work, really helped. |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Speed Up the Performance of Vista Your welcome Frozen. |
| Vista Ultimate x64 | Re: Speed Up the Performance of Vista Fantastic document Works a treat too Thanks! |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Speed Up the Performance of Vista Your welcome MNP, and welcome to Vista Forums. |
| Vista Ultimate X64 SP1 | Re: Speed Up the Performance of Vista Great guide. Thank u very much |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Speed Up the Performance of Vista Your welcome ZoK-StaR. |
| Tutorial Tools | |
| Tutorial | Category | |||
| How to test USB speed / performance | Vista hardware & devices | |||
| Oblivion and Vista Speed/Performance :: Help Needed | Vista Games | |||
| speed and performance information | Vista performance & maintenance | |||
| Using a Flash USB thumb drive to speed up performance? | Vista installation & setup | |||
| ReadyBoost, Speed up your PC’s performance | Vista General | |||
