Speed Up the Performance of Vista
How to Speed Up the Performance of Vista
This is a list of suggestions that will show you how to speed up the performance of Vista.
These are suggestions that you can pick and choose which ones you would like to do. If you do not notice a increase in performance or have a problem, you can always go back and enable it again or undo it.
MINIMUM SYSTEM REQUIREMENTS FOR VISTA
NOTE:
It is recommended to have at least 3 GB of ram to help have good performance. For more information, see: Microsoft Windows Vista: Recommended System Requirements
Vista Home Basic
  • Processor: 1GHz (32 or 64 bit)
  • System Memory (RAM): 512MB
  • Hard Drive: 20GB with 15GB available for Vista
  • Video Card: 32MB Memory and DirectX 9 Support
  • DVD-ROM Drive
Vista Home Premium, Business, or Ultimate
  • System Memory (RAM): 1GB
  • Hard Drive: 40GB with 15GB available for Vista
  • Video Card: 128MB Memory, DirectX 9 Support with: WDDM Driver, Pixel Shader 2.0, 32bits per pixel
  • DVD-ROM Drive
Here we go:
1. Uninstall the Bloatware From Your Computer
Most computers that you buy, at a retail store or OEM, have a ton of software that come installed on it. Some of these can take up a lot of resources. Uninstall the ones that you do not want to use from Programs and Features.​
2. Install the Latest BIOS and Device Drivers
Make sure that you have the latest drivers installed for all of your devices and BIOS version for your motherboard. Check at the device's website for them. Be sure to have the correct versions for your 32 bit or 64 bit Vista.
3. Install More RAM
The more you have the better your performance can be up to a point. Usually 3 or 4 GB will be the most you will need. I would recommend to have at least 3 GB of RAM to help have good performance.
4. Install Vista SP1
Installing SP1 can help improve your performance with the updates that it provides to Vista.​
5.Turn Aero Glass Transparency Off
The glass effect used by Aero uses a large amount of resources. You can switch it off without disabling Aero.​
6. Adjust Visual Effects for Best Performance
Uncheck the options you do not want or select for best performance to increase the speed. You can optimize performance by changing how menus and windows appear.​
7. Enable Advanced Performance for the Hard Drive
By default Vista does not enable write caching for SATA (Serial ATA) hard drives or advanced performance for SATA or ATA drives. To improve your data retrieval speed you must enable the write caching and advanced performance.​
8. Disable the Search Index
Vista search index constantly reviews files on your PC to make their contents available for quick searching. This is a nice feature, but it can impact system performance by the hard drive running more often and often gives inaccurate results due to not being finished updating yet.​
9. Disable or Remove Unused Startup Programs
Go through your startup programs and disable the ones you do not want to start when Vista starts. It is a good idea to check these every once in awhile to help make sure that some malware is not starting up with Vista too.​
10. Disable Unused Vista Services
Use the guide below and disable only the services you will not be using. They can consume lots of RAM and processor usage.​
11. Disable or Restrict TCP/IP Auto Tuning
NOTE: This is only for when you are having a slow or problematic network issue.
12. Turn Off Remote Differential Compression (RDC)
NOTE: For more information on Remote Differential Compression, see: Microsoft MSDN: About Remote Differential Compression
Remote Differential Compression measures the changes in files over a network to transfer them with minimal bandwidth rather than transferring an entire file that has previously been moved. By constantly checking for file changes, this service can hinder system performance. You can uncheck this option in Windows Features to turn it off.​
13. Turn Off Extra Unused Windows Features
Vista ships with many other features that are listed separately from the startup services. You can review and disable these features here.​
14. Turn Off Automatic Disk Defragmentation
Vista comes configured with hard drive defragmentation automatically scheduled and can cause a system slow down with its always-on defragment feature.​
15. Defragment the Hard Drive on a Regular Schedule
Disk fragmentation leads to system slowdowns, PC crashes, slow startup and shutdown and sometimes to system failures.​
16. Defragment the Registry
Unlike registry cleaning utilities, no entries are removed from the registry. Instead, wasted space is reclaimed and the files are defragmented in the registry to improve performance. Free Registry Defrag is a great free program for this.​
17. Turn Off the Hibernation Sleep Mode
Vista's hibernation background services use a large amount of system resources and hard drive space. Set the Hibernate after to Never. You will want to use the Hybrid sleep instead.​
18. Turn Off System Restore
Analysis and restore point creation by Vista can use a fair amount of system resources.​
WARNING: Disabling System Restore will mean that there will be no restore point available to go back to in the event of a problem with your computer. You will need to make backups if you disable System Restore.​
19. Turn Off Windows Sidebar
Each Sidebar gadget consumes system resources, so either trim back what you use to a minimum or turn off the Sidebar completely.​
20. Speed Up the Menu Pop Out Delay Time
This will speed up all menu slide outs or pop ups delay time in Vista to make them open faster.​
21. Use ReadyBoost
Windows ReadyBoost can use storage space as a memory cache on some removable media devices, such as USB flash drives, to speed up your computer.​
22. Use Disk Cleanup
This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have.​
23. Speed Up the Boot Time
This will show you how to speed up just the boot up time to your desktop in Vista.​
24. Speed Up the Shutdown Time
This will set the amount of time Vista waits for programs to save data and close before shutting down.​
25. Use the High Performance Plan in Power Options
This will allow your CPU to operate up to it's full 100% instead of the default 50% in the other Plans. See step two here:​
26. Make a Program or Process Run with a Higher or Lower CPU Priority
If you have a large resource demanding program or process running, then setting it to a higher CPU priority will allow it to run faster.​
27. How to Set the Processor Affinity for a Application in Vista
Like setting the CPU Priority (See 27 above) , you can set the Processor Affinity to have a application (Ex: Anti-Spyware scan) to use only one CPU while you have another application (Ex: Internet Explorer) running on just the other CPU to allow maximum usage of each CPU assigned to each application.​
28. Change or Disable the QoS Reserved Bandwidth Limit
By default, Vista can reserve up to 20 percent of the network bandwidth for QoS traffic handled by the QoS Packet Scheduler. One hundred percent of the network bandwidth is available to be shared by all programs unless a program (Ex: Windows Update) specifically requests priority bandwidth. This 20 percent reserved bandwidth is still available to other programs unless the requesting program (Ex: VoIP applications) is sending data. Vista can then restrict the best effort traffic to a minimum of 80 percent of the bandwidth to the other programs so that the high priority traffic can be accommodated. If the program that reserved the bandwidth is not sending sufficient data to use it, the unused part of the reserved bandwidth is available for other data flows on the same host.​
29. Set Vista for the CPU L2 Cache Memory Size
This can increase performance by approximately 2 percent in some cases. You will need to read the description at the link. It's to long to place here.​
30. Add COPY TO FOLDER and MOVE TO FOLDER to the Context Menu
Copy To Folder allows you to right click on a item and copy it to another location immediately.
Move to Folder allows you to right click on a item and move it to another locatation and remove it from it's current location immediately.
31. Disable the Transient Multimon Manager (TMM)
This is the 2-3 second delay followed by a blank black screen as Vista searches for monitor changes when you startup Vista. Disabling TMM will stop this. Be sure to read the Warning.​
32. Adjust Superfetch to Meet Your Needs
Superfetch is a new improved feature in Vista that monitors which applications you use the most and preloads these into your system memory (RAM) so they'll be ready when you need them. You can change Superfetch to preload only the Boot files, Program files, or the default both Boot and Program files into memory, or disable it completely. In most cases, leaving Superfetch set to default will help Vista run faster over time. Test and see for yourself.
33. Clear the Vista Temporary Files
The Temp folder is where Vista and programs sometimes store temporary files. Sometimes these files are not deleted after Vista or the program is finished with them. This can cause the temp folder to fill up with junk temp files which may cause Vista to take longer to access the Temp folder and create a slight delay.​
34. Turn Windows Explorer Thumbnails Off
If you do not care about having thumbnail images for the file icon and the default icon is fine, then this can help speed up navigating in Windows Explorer by Vista not having to load the images for the icons.​
35. Change the Maximum Download Sessions in Internet Explorer or all Browsers
This can help increase the speed of Internet Explorer or the browser that you use.​
A) The current HTTP specification limits the number of simultaneous file downloads to two downloads, plus one on stand by. As connection speeds increase, the number of simultaneous downloads to a single web server may not be enough for your needs.​
B) If you visit a web page with lots of images (and supporting files like CSS styles and Javascript), then you can have a slower browsing experience. On average, your browser would have to make more than 40 requests to the server before it can assemble the complete page. Requesting all the files you need with the default 2 at a time is going to be slower than requesting say 10 files at a time.​
36. Change the Number of Processors Used at Boot Up in Vista
If you have a multiple core CPU (Ex: Intel Core Duo or Quad CPU) or multiple CPUs, then this will show you how to change the Number of Processors that will be used durring boot up that has been reported to help speed up the boot up time even though Vista uses all available Cores or Processors by default.​
37. Disable Clearing the Virtual Memory Paging File at Shutdown
When this setting is enabled it can add around a minute or so to how long it takes your computer to shutdown and restart.​
38. Enable Defragmenting of Boot Files at the Startup of Vista
When enabled, this can help improve the performance of the computer by consolidating the fragmented boot files to get a faster startup time. This should be enabled by default in Vista, but it would not hurt to double check.​
39. Move the Virtual Memory Paging File to a Second Hard Drive
You can place the paging file on a second physical hard drive instead of the same C: drive that Vista is on. Doing this allows Vista to dump temp junk onto one drive while not having to interrupt reads or writes on the other drive. You can expect a 5 to 10% increase in speed depending on the speed of your hard drives.​
40. Change the Mouse Hover Delay Time
The mouse hover delay time is how long the mouse pointer has to stay hovered over an item, in milliseconds, before that item's pop-up is displayed. For example, pop-up descriptions or taskbar thumbnails.​
41. Install Vista SP2
Installing SP2 either through Windows Updates or the standalone installer can help improve your performance with the updates that it provides to Vista.​
42. Use a Solid State Drive (SSD)
Installing Vista onto a solid state hard drive (SSD) instead of a normal SATA or IDE hard drive will dramatically increase your computer's performance.​
43. Turn off all unnecessary animations
If animation effects, such as fade windows when closed visual effects, run slow or sluggish on your computer, then using Turn off all unnecessary animations can help improve your computer's performance.​
I will add more as I find them,
Your welcome Evan,
I hope it helped speed up your system.
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
Great job, Shawn! I hav'nt done all in the list yet, but I see improvement already. I really like 6 and 7. Thanks again.
    E6850
    EVGA 122-CK-NF67-A1 680i
    4 x OCZ Platinum 1GB
    ATI Radeon HD 5850 1GB
    SB X-Fi X Audio
    Samsung 23" 5MS
    2048 x 1152
    Seasonic 600W M12
    CM Centurion 5
    air
    100Mbps
Your welcome bruce2,
I'm glad to hear that your computer's performance has improved. Thank you for the feedback.
Your welcome Jlaprise, and welcome to Vista Forums. :party:
Your welcome manumistral, and welcome to Vista Forums. :party:
Hi Brink, wow I can't wait to get started. This may be a silly question, but how do I know what kind of mother board I have so I can update the Bios? I have an HP Pavillon with an AMD 64x2 dual core processor 4800 + 2.5ghz. 1918mb ram. Oh, and 32 bit op system.
Thanks, Case
Thanks, Case
Hi Case,
Do you know the model number of the HP Pavillion?
Case,
You can download the BIOS from here:
Software & Driver downloads HP Pavilion Media Center TV m8013w Desktop PC
If you need specs on your system, then see:
HP and Compaq Desktop PCs -  Motherboard Specifications, M2N68-LA (Narra)
Any reputable retail place (Online or Store) is great place to buy RAM. I would just go with who has the best price for the RAM you need. Online may be a bit cheaper, but a store is easier and faster to deal with if you have problems with the RAM.
Your welcome Case. I'm glad that you like the site.
Shawn, another question if you don't mind. When I turned off remote differential compression, I noticed in your example, you have Windows DFS Replication service turned off. Mine is checked. Should I uncheck it? Also, on step 16 do I have to enable 'yes' on Require a password on wakeup. Mine is set to 'no'.
Thanks,
Casey
Hi Case,
If you do not need DFS Replication, and most people do not, then it will be fine to uncheck. You can read more on it here to determine if you do need it or not.
Windows Vista SP1 Services Information - DFS Replication
If you want it set to where you have to enter a password when the computer wakes up from sleep or hibernation, then yes you will need to select Yes.
Your welcome Case.
