Vista Forums Home Join Vista Forums Windows 7 help and support Forum Windows 8 Forum Vista Tutorials
Vista - Mouse Hovering to Activate a Window
Comment
How to Activate a Window by Hovering Over it with the Mouse Pointer in Vista
Published by Brink
08-30-2007
This will allow a window to be activated by hovering the mouse pointer over the window for a second to make it easier to switch between open windows.
1. Open Control Panel. (Classic View)
2. Click on the Click to Play button in the video below.
Published by
Brink's Avatar
Administrator
Brink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond repute
Brink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond repute
Tutorial Tools
Applies to
All Vista Versions
64 Bit & 32 Bit
12-03-2008
moshepp
Vista Ultimate x64
Re: Mouse Hovering to Activate a Window
I went to the above section and the field is NOT activated. If I do not move the mouse away from an email message, a link or an icon on my desktop, it will take me there automatically. How do I fix this.? It is driving me nuts!
12-03-2008
Brink
Vista x64 Ultimate SP2, Windows 7 Ultimate x64 SP1
Texas, USA
Hello Moshepp,
The feature in this tutorial is for only for activating a window while hovering, and not a link or icon though.
Is this for a mouse or touchpad?
If a touchpad, you might look in the control panel, mouse, device settings, settings, and UNCHECK "Enable Tapping" to see if that can help.
If mouse, you might look for a similar feature for that brand of mouse.
Hope this helps some,
12-03-2008
moshepp
Vista Ultimate x64
Thank you for the reply. You were correct that it was the touchpad. I wasn't connecting the two as being different. I went to the Tapping site and it was not checked. I checked it, came out and went back in and unchecked it. It seems to have worked. I'll let you know if it starts again. Thanks for the help.
12-03-2008
Brink
Texas, USA
You're welcome Moshepp. I'm happy to hear that it seems to have stopped for now.
01-16-2009
LMURRAY
vista home 32bit
I don't know if I am doing this correctly, but I "think" I have followed the directions correctly, but when I move my mouse over File, Edit, View, etc nothing happens.
When I hovering my mouse over one of the icons on the Yahoo toolbar, nothing happens.
What or how is supposed to work? I was thinking that doing one of the above would open a menu or window.
I would appreciate your help.
01-16-2009
Brink
Texas, USA
Hello LMurray.
You would want this tutorial instead for the menus.
Menu Show Delay Time
Comment
 Mouse Hovering to Activate a Window problems?
Tutorial Tools
Similar topics to: Mouse Hovering to Activate a Window
Tutorial Category
Regarding "Activate a window by hovering over it with the mouse" Vista General
Activeate a window by hovering over it (THE TITLE BAR) with the mouse Vista General
Solved hovering over windows using mouse General Discussion
Mouse hovering Vista mail
Mouse hovering Vista General
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
