Context Menu - Add COPY TO FOLDER and MOVE TO FOLDER
How to Add "Copy To Folder" and "Move To Folder" to the Context Menu in Vista
Copy To Folder allows you to right click on a item and copy it to another location immediately. Move to Folder allows you to right click on a item and move it to another locatation and remove it from it's current location immediately.
This is also under the EDIT menu in a Explorer window. (See Example screenshot below)
EXAMPLE: Default Edit Menu Location:
NOTE: These are the keyboard shortcuts to use the Menu bar location while having the file or folder selected that you want to Copy or Move to another folder.
  • Copy To Folder - Press and hold Alt then press E and F
  • Move To Folder - Press and hold Alt then press E and V
EXAMPLE: Copy To Folder and Move To Folder Added to the Context Menu:
NOTE: Right click on a file or folder to see your new additions. You can see what happens when you click on each one beside the context menu screenshot. You can select a different drive to.
METHOD ONE
Using a REG File Download
1. To Add Copy/Move To Folder
NOTE: You can add one or both of these.​
Add_CopyMove.reg
download
B) Go to step 3.​
2. To Remove Copy/Move To Folder
Remove_CopyMove.reg
download
METHOD TWO
To Do Manually in Registry Editor
1. Open the Start Menu.​
HKEY_CLASSES_ROOT\AllFilesystemObjects\shellex\ContextMenuHandlers
5. To Add Copy To Folder
A) In the left pane, right click on ContextMenuHandlers and click on New and Key.​
B) Type {C2FBB630-2971-11D1-A18C-00C04FD75D13} and press Enter.​
NOTE: To Remove Copy To Folder - Right click on this key and click on Delete.
6. To Add Move To Folder
B) Type {C2FBB631-2971-11D1-A18C-00C04FD75D13} and press Enter.
NOTE: To Remove Move To Folder - Right click on this key and click on Delete.
7. Close regedit.​
  • Remove_CopyMove.reg
  • Add_CopyMove.reg
Your welcome Hgjazz,
Welcome to the forum. :party:
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
Your welcome Janelte.
Thanks Brink. I've been looking for just this very option, as after dabbling in Linux I find it an extremely useful feature. I tried installing using Method 1. It hasn't worked for me, even with a restart. I'm using Vista Home Premium 32bit. What do you suggest I try next to get this working? Method 2?
Hi Badcam,
It will work for all Vista version. I would go ahead and do Method Two. You can Copy and Paste the codes from the tutorial to make it easier to do.
Hi Manteca,
The Move To Folder will act the same as Cut To Folder would. It will remove the file or folder from the original location and move it to the folder you selected. ;)
Your welcome manteca,
Anytime.
I registered simply to thank you for this. The reg file merged perfectly with my 32bit version and I have exactly the functionality I was looking for.
Perfection would be if there was a way to finagle the 'send to' function to move by default instead of copying.
Anyway - kind thanks
David
Your welcome David,
That would be nice.
Your welcome LengIeng.
Hello Brink,
I thought I had this on my last install but maybe not.
I wanted it back! Method Two was a piece of cake; I did copy/paste the key without incident.
I already used Move To, worked like a charm!
Thanks Shawn.
Later :shock: Ted
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    HP Enhansed Multimedia
    Razer Diamondback 3G
    18.6Mb/s
    My First Build ;)
Your welcome Ted.
thanks Brink, that link is important..
    Intel 2140 3.2GHz
    Intel (R) 946GZ
    2.0GB
    Intel Graphics Media Acclerato
    160GB
Your welcome Silent_Guardian.
Thank you,
