Vista - Startup Repair
Comment
Old 09-11-2007
Brink
Startup Repair
How to Do a Startup Repair in Vista
Old 11-13-2008
Brink
Re: Startup Repair
Quote  Quote: Originally Posted by mansrm81 View Post
Quote  Quote: Originally Posted by Brink View Post
Hello Blackhawk,
You have a OEM recovery cd that is not capable of doing a Startup repair, only a clean install of Vista to factory defaults instead.
You can do a startup repair by booting in to the recovery by hitting F11 for HP or whatever the key is to boot into the recovery partition and do a startup repair.
Oh, nice to know that. Thank you Mansrm81.
Old 11-13-2008
blackhawk
Vista Home Premium 32bit
Re: Startup Repair
tnx again shawn this actually resolved my problem.. tnx.. ur the best..
Old 11-13-2008
Brink
Re: Startup Repair
You're welcome BlackHawk. I'm happy to hear that you got it sorted.
Old 11-22-2008
case998
vista 64 bit home premium
Thumbs up Re: Startup Repair
Just want to say a big thanks to shawn. Having just purchased a new laptop found it wouldn,t boot at the second time of asking so i rigged up my old system(good job i hadn,t sold it)found this thread and made a repair cd and it worked at the 1st attempt,so again many many thanks and an excellent forum
Old 11-22-2008
Brink
Re: Startup Repair
You're welcome Case, and welcome to Vista Forums. I'm happy to hear that you got it sorted.
Old 11-23-2008
case998
Re: Startup Repair
Whent to restart and same bios screen came back again, booted from the repair disk but why wont it boot from hdd,this is a brand new 64bit vista home premium version and it started up ok 2 days ago when i recieved it, i think i might after look at sending it back to acer now tried again and opted not to repair from 1st option so canceled that and then noticed the diagnostic tool had not detected any o/s (COULD IT BE LOOKING IN THE WRONG PARTITION)clicked next anyway as posted earlier and got the full diagnostic screen, clicked repair and when it came to boot i never hit any key to boot from cd and it booted up fine. I then changed the boot options back to hard drive removed the repair disk and restarted the computer and hey presto all was well untill the next time when it went back to the bios screen so what the hells going on here i dont know. Any ideas greatly appreciated before i top myself or mi head self explodes.
Old 11-23-2008
Brink
Re: Startup Repair
Case,
I have added Method One to help as well since you have a OEM Vista, but it's pretty much the same method with a different way of getting there.
Do you have more than one physical hard drive installed? I had this happen to me one time where my system was trying to boot off the wrong hard drive that Vista was not installed on. I had to unplug the other hard drive, ran Startup Repair for the Vista drive, then plugged back in the other drive to fix it.
If this is not the case, then double check to make sure that you are selecting the correct partition with Vista on it in step 5 (Method Two).
Old 11-23-2008
case998
Re: Startup Repair
OK will give that a go, its defo got 2 partitions c and d and there a windows icon at the c side and nowt at the d side if yer see what i mean. Thanks for the reply. Oh ive been on it all day and its purring along nice when it boots upIts not detecting any vista o/s,as in method 2 step 5 why is that do you think?
Old 09-13-2009
havocwreaker
Vista Ultimate x64
Re: Startup Repair
Quote  Quote: Originally Posted by qwerty855 View Post
Hi -
For step 5: What if there isn't an operating system listed?
Shawn,
I hope you can help me. I have the same issue but when I click NEXT and Select Startup repair it says that it performed fixes and that I have to restart. When I do I still have a blue screen after load bar but prior to log on screen.
I perform regular restore checkpoints and backups but I can access none of them in the Repair Tool. I don't know why as the Backups are kept on a separate external drive (Striped).
The command prompt does not allow me access to the C: drive. It just stays hanging on X:\sources
Here's how the problem first occurred:
I left my house this morning and left the PC on. Upon my return the computer had a black screen. When I rebooted it asked me to run chkdsk and started the countdown so that I could stop it. I figured I would allow it since it had been a while and it found corrupt indexes and made corrections. Upon completion. It could no longer boot into the OS.
Thanks to anyone in advance for a reply. I realize the thread is a bit old but I really need the help. My home business relies on this PC.
Old 2 Weeks Ago
stone63
Re: Startup Repair
Hi
im having similar issues, however, when I startup my laptop it comes up with system restore options, as you have posted on the first page. when it comes to selecting an operating system, there are none displayed. I've been working with it for a few days now, and even though I click next 'without worrying', it goes to attempt repair but fails.
any ideas?
Comment
Tutorial Tools
Tutorial Category
Vista Startup Repair cannot repair this computer automatically Vista General
HELP! Startup Repair General Discussion
Startup repair cannot repair this computer automatically Vista General
startup repair Vista General
Startup Repair Vista General
