Unassociate File Extension Type
How to Unassociate a File Extension Type in Vista and Windows 7
This will show you how to set a file extension to be associated with nothing for all users instead of some default program without having to delete the file extension unless you wanted to.
This is a standalone EXE program that does not install to your computer.
CREDIT TO:
Ramesh Srinivasan -www.winhelponline.com/articles/231/1/
1. Download the free unassoc.zip file and save it to your desktop.​
2. Right click on unassoc.zip (On Desktop) and click Open.​
3. Extract both files to the desktop. (See screenshot below)​
4. Click on the Unassoc.exe icon to run the program.​
NOTE: I would recommend that you put these two files in a new folder and save them in your C:\Program Files folder, then make a shortcut for the Unassoc.exe to use.
5. Click on Continue in the UAC prompt.​
6. To Unassociate a File Extension Type
A) Click on a file extension type from the list in the left pane to select it. (See screenshot below step 7)​
B) Click on Remove file association (User).​
7. To Delete a File Extension Type
A) Click on a file extension type from the list in the left pane to select it. (See screenshot)​
B) Click on Delete file type.​
8. Close program when done.​
Hi, I have been trying desperately for 3 hours to remove the association of the file type .INS from the program "Inspiration" (Document Mapping) so that I can run an .INS file as an "install shield script" file. I tried your tutorial and, sure enough, in the control panel, the ".INS" file type is no longer associated with Inspiration. However, when I look at my downloaded copy of a new program that I want to install that includes the .INS file type, it is still associated with Inspiration! It is EVIL! Can you help me? Thanks!
Hi Elisabeth,
If you installed a program that added the .INS extension, then you can reinstall it to add it back so you can unassociate it.
You can also right click on the .INS file and use Open With to select a EXE program to use to open it with.
http://www.vistax64.com/tutorials/69758-default-programs.html
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
When I run the program and find the file I want to unassociate the Remove file association (User) is grayed out. What else can I do do unassociate.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Western Digital 160 GB IDE
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
Hello Mansrm. What file extension are you wanting to unassociate?
.001 from 7-zip I didn't want to always open with that program.
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
.001 from 7-Zip? I do not see a file extension listed for that in 7-Zip. :confused:
Anyways, you can unassociate it by: :)
I did the open with and associated it that way.
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
OK, I'm glad that you got it sorted out. :)
Hello Bluefire, and welcome to Vista Forums.
You might download and double click on the REG file I attached below, then restart the computer to see if it may help. It will remove the registry entries for the .blob file extension to hopefully unassociate it for you.
  • Unassociate-BLOB.reg
When I run the program and find the extention .dat (which I want to unassociate) the Remove file association (User) is grayed out, what can I do?
Sorry, it doesn't work, it appears "Impossibile importare C:\...\Default.reg: non tutti i dati sono stati scritti correttamente sul registro. Alcune chiavi sono utilizzate dal sistema o da altri processi."
Which means: "It is impossible to merge C:\...\Default.reg: there are some data which are not correctly written on the register. Some keys are being used by the system or some other process."
Hi Robs,
Try doing this:
  1. Open your start menu
  2. In the search box, type regedit.exe
  3. Right click on the search regedit.exe and select Run as administrator
  4. Navigate to: HKEY_CLASSES_ROOT/.dat
  5. Click the on a key you want to take ownership of.
  6. On the Edit menu, click Permissions.
  7. Click Advanced, and then click the Owner tab.
  8. Under Change owner to, click the new owner, and then click OK.
  9. Repeat for the other keys in that folder
  10. Try running that .reg file again, as instructed by Brink
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    Samsung EVO 128GB SSD
    Seagate Barracuda 2TB 7200rpm
    NZXT Phantom 410
It works! :) Thanks a lot buddies, you were awesome!
Thanks for letting us know how it went. I'm glad we managed to get you all up and running again :)
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
That's great news Robs. I'm happy to hear that you got it sorted. :)
