| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Disk Management - Delete and Extend How to Delete and Extend a Partition with Disk Management in Vista Last edited by Brink; 04-17-2009 at 01:09 AM.. |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Disk Management - Delete and Extend Hi Miguel, Welcome to Vista x64 Forums. ![]() When you get to step 6, are you right clicking on the drive partition that you want to make bigger, not the one you deleted, to click on Extend Volume. This will usually be the drive partition to the left of the one you deleted. Shawn |
| ultimate 32bit | Re: Disk Management - Delete and Extend thanks this really works i mean it thanks ![]() ![]() ![]() ![]() |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Disk Management - Delete and Extend Your welcome acid2k1, and welcome to Vista Forums. ![]() Shawn |
| Visat Ultimatex32 | Re: Disk Management - Delete and Extend This method would not let me extend the volume with Vista on it (C:\) the Extend... was grayed out, but it would let me extend the D:\ that has my XP installation on it... ALL are on the same disk! how do i get around this? I followed the instructions to a T. Thanks |
| Vista Ultimate x64 | Re: Disk Management - Delete and Extend This method did not work for me. I have C:, D: and E: partitions on the same HDD. OS is on C. I shrinked D: and tried to add this new allocated space to C. But "extend volume" option on C was grayyed. Why cannot I extend my C? |
| Vista x64 Ultimate | Re: Disk Management - Delete and Extend Do you have the free space next to C: partition? C: Free D: E: to have a chance at working. You can't extend C: D: free E: will not work. Free space has to be next to the partition. |
| Vista Ultimate x64 | Re: Disk Management - Delete and Extend |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Disk Management - Delete and Extend Hi Hasan_hzl, You can make Free a separate partition and copy the data from D: over to it, then delete D: and extend C: into D: to have C: - (new Free with letter) - E: . It's a bit of a shuffle, but it will work. Hope this helps, Shawn |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Disk Management - Delete and Extend Your welcome Hasan_hzl. Shawn |
| Tutorial Tools | |
| Tutorial | Category | |||
| computer management-disk management problem | General Discussion | |||
| Computer Management - Disk Management... | Vista General | |||
| why extend option in disk management is gray? | Vista General | |||
| Computer Management --> Storage --> Disk Management | Vista account administration | |||
| Hard drive management - extend | Vista General | |||
