Vista - Disk Management - Delete and Extend
Comment
Old 09-28-2007
Brink
How to Delete and Extend a Partition with Disk Management in Vista
Old 07-26-2008
hasan_hzl
Vista Ultimate x64
Re: Disk Management - Delete and Extend
Quote  Quote: Originally Posted by hasan_hzl View Post
Quote  Quote: Originally Posted by Brink View Post
Hi Hasan_hzl,
You can make Free a separate partition and copy the data from D: over to it, then delete D: and extend C: into D: to have C: - (new Free with letter) - E: .
It's a bit of a shuffle, but it will work.
Thanks. I will try
I did not try because I installed many programs on D: hence it is impossible to move folders to other drives. Is not there any other way to do my stuff by using some programs? I tried to use Paragon Partiton Manager but it did not help me. I know this is not a big problem but I want to learn if ther is any programs.
Thanks for your helps again.
Old 07-26-2008
Brink
Acronis Disk Director is a good one to use. I do not know if the trial version will do what you want, but the full version should.
Hard disk drive management software, partitioning manager and partition recovery utility
Old 07-26-2008
hasan_hzl
Vista Ultimate x64
Acronis Disk Director Suite is not working. I think it is not x64 compatible
Thank you.
Old 08-06-2008
hockeymansp
Vista Home Premium 32bit
I would like to delete a partition on my harddrive but it is located on the LEFT of the partition I would like to extend. I was about to delete and extend as described in this forum but I noticed the directions are for deleting partitions located on the RIGHT of the partition you want to extend. Can I follow these instructions without losing data?! I would really appreciate any help! Thanks in advance.
Old 08-06-2008
ripbox
vista ultamate 64bit
does it matter what side the partition is displayed on?
and out of curiosity i took a look at my Disk management and noticed that although i don't have any partitions i do have 1.47GB of un allocated space, what's all that in aid of?
Old 08-06-2008
Brink
Hi Ripbox,
To extend a partition, you must use a unallocated partition (deleted) directly to the right of the partition you want to extend and not to the lefft or two or more over to the right.
To shrink a partition to create a new one, you can use any partition that has enough free space to do so with. It will create the new partition directly to the right of the partition you are shrinking. However, the you can only create up to 4 partitions per drive.
In your case, I'm not sure what the 1.47 GB of unused space was setup for. You can pick up at Step Two in this tutorial to Extend C: into the 1.47 GB partition so it will be one drive again and gain that space back.
Old 08-13-2008
stlhkr
Quote  Quote: Originally Posted by Tank View Post
This method worked out fine. As I had one primary partition and 2 logical drives on same disk C:\. I deleted both the logical drives D: & E: It gave me green marked new volume. The C:\ Extend Drive feature was grey then. I dleted the new green volume and then tried Extension of C:\. It worked out fine and now full volume of C:\ is dedicated to Vista.
This method worked beautifully. Took less than 5 minutes on a Lenovo Y410.
Old 08-14-2008
comer
32bit
As fa as I am concerned, some partition tools are easier to use and have more functions...I am always using Easeus Partition Manager Home Edition, which is a freesoftware.
however, it cann't be operated in Vista....
Old 08-14-2008
Brink
Hi Comer,
Any decent 3rd party partition program should have more features and options than Disk Management in Vista. Unfortunately, it was only meant for basic use.
Sorry about your favorite program not working in Vista.
Old 09-29-2008
bobcorn1990
Thank you very very very much
you have saved my life,
I've been searching for 2 month for that, and in just 20 sec , i was able to solve my problem with that
thanks again
Comment
Tutorial Tools
Tutorial Category
computer management-disk management problem General Discussion
Computer Management - Disk Management... Vista General
why extend option in disk management is gray? Vista General
Computer Management --> Storage --> Disk Management Vista account administration
Hard drive management - extend Vista General
