Vista - Disk Management - Delete and Extend
Comment
Old 09-28-2007
Brink
How to Delete and Extend a Partition with Disk Management in Vista
Old 09-29-2008
Brink
Re: Disk Management - Delete and Extend
Your welcome Bob, and welcome to Vista Forums.
Old 12-19-2008
bennys
window vista
Hello !
OK, this might be unimportant but it's been bothering me for awhile.
I have two drives, C:(for Vista OS), E:(XP OS). and an unallocated space next to my E: drive.
Although it's only 9MB, I cannot put it to use nor get rid of it. Neither C: or E: could be extend(greyed out).
Can you please tell me what the solution to my problem is?
Thanks. Here are my partitions:
Old 12-20-2008
Brink
Hi Bennys,
If you feel comfortable with this, you can see if using the Diskpart command to try and expand the E: drive's volume number into the 9MB unallocated space. This MS article will help explain how to.
How to use Diskpart.exe to extend a data volume in Windows Server 2003, in Windows XP, and in Windows 2000
If not, then I would just wait until the next time you do a clean reinstall, then use the advanced disk management option while installing Vista to sort the partitions.
Old 12-21-2008
bennys
window vista
Thank you Sean.
It was pretty intimitaing at first but I followed the steps and successfully accomplished the task.
Thanks.
Old 12-21-2008
Brink
You're welcome Bennys. I'm happy to hear that you got it sorted.
Old 12-24-2008
tom8152000
x32
hi
the method is not working in my addition. i have 4 drives and i want to combine two of them into one drive, but after i deleted one and i can not extend any of the other of three
can u help me please
Old 12-24-2008
Brink
Hello Tom, and welcome to Vista Forums.
Could you post back a screenshot of Disk Management with all of the drives to help determine what may help?
If they are separate physical hard drives and not partitions, then you cannot combine (extend) them like that in Disk Management.
Old 12-24-2008
tom8152000
x32
here is the screenshot:
Old 12-24-2008
Brink
Tom,
You can use the same method I descibed above for Bennys to do this.
If you feel comfortable with this, you can see if using the Diskpart command to try and expand the D: drive's volume number into the 10MB unallocated space. This MS article will help explain how to.
Old 12-24-2008
tom8152000
x32
i go try it thanks
Comment
Tutorial Tools
Tutorial Category
computer management-disk management problem General Discussion
Computer Management - Disk Management... Vista General
why extend option in disk management is gray? Vista General
Computer Management --> Storage --> Disk Management Vista account administration
Hard drive management - extend Vista General
