| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Disk Management - Delete and Extend How to Delete and Extend a Partition with Disk Management in Vista Last edited by Brink; 04-17-2009 at 01:09 AM.. |
| Vista Home Basic, 32bit | Re: Disk Management - Delete and Extend Thanks Brink, It worked Thanks for your support and quick replies |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Disk Management - Delete and Extend You're welcome Gene. |
| Vista Home Premium | Re: Disk Management - Delete and Extend I went through the initial steps of this tutorial and found that the first volume listed in Computer Management is a "Disk 0" or perhaps Disk capital-oh O. Its status displays as Simple Basic Healthy (EISA Configuration) What is this thing? The overall readout for the computer's harddrive? Do I need to be worried about it if I want to delete the D: partition? Background: I'm brand new to Vista, having inherited an Vista-driven Acer 4520 with almost no data on it. I'm a seasoned XP guy, with two Dell Inspirons rendered worn out. This Acer belonged to a relative who was apparently upgrading her technology shortly before she passed. Associated question: would Acer have shipped the laptop with this partition already in place, or would she have had needed someone do it for her? It's a 120GB harddrive, with 51.14GB on C: and 50.89 on D:, yet 9.76GB on this mysterious Disk 0. I'd like to merge all three into one C:. (Many thanks for your work here! VERY well done!) |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Disk Management - Delete and Extend Hello IvyGold, and welcome to Vista Forums. It is the number 0 for "Disk 0". Since you have a OEM (Acer) computer, the C: drive is Vista. The D: drive is the OEM recovery partition used to restore Vista back to factory default on the C: drive. The "Disk 0" partition is a hidden EISA partition used by the recovery partition to restore all of the included programs that came with your OEM computer. Unless you have a set of OEM recovery CD to use instead of these partitions to restore Vista with when needed, then I would not delete or mess with them. Hope this helps, Shawn |
| Vista Home Premium | Re: Disk Management - Delete and Extend Unfortunately the recovery discs haven't been found yet. So are you saying not to mess with either non-C: partition? My problem is that both C: and D: are 50 GB each, but I have an iTunes database of 55GB. Following your instructions above wouldn't let me merge the D: GB's into the C:? I'm OK leaving Disk 0 alone. (And thank you for your help!) |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Disk Management - Delete and Extend IvyGold, Do not touch the other partitions. If you do, you will not be able reinstall your OEM Vista again. This may help with creating a set of recovery CDs of your own to use instead. How to create ACER Vista Recovery disks |
| Vista Home Premium | Re: Disk Management - Delete and Extend Excellent, I'll do the recovery DVD route before touching anything. Why did Acer do this? Having two 50GB partitions destroys the usefulness of a single 100GB harddrive. An afterthought: there's virtually no data on this computer, and thereby nothing to risk losing yet, so I was thinking about skipping getting up to speed with Vista completely and moving directly to the Windows 7 beta. Would I be able to join the C: and D: partitions during that process? (And of course doing so after creating the recovery DVD.) Thanks again, I REALLY appreciate it! |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Disk Management - Delete and Extend IvyGold, Yes, after you create and test the recovery CDs to be safe, you can delete the partitions during the installation of Windows 7 in the Drive (advanced options) step. Clean Install Windows 7 Beta - Windows 7 Forums You can get Windows 7 Beta here with a product key for activation. Download the Windows 7 Beta |
| Vista Home Premium | Re: Disk Management - Delete and Extend Excellent. I think that's what I'll do. Thanks again, and see you in the Windows 7 forum in a month or two. |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Disk Management - Delete and Extend I'll be looking forward to seeing you there. |
| Tutorial Tools | |
| Tutorial | Category | |||
| computer management-disk management problem | General Discussion | |||
| Computer Management - Disk Management... | Vista General | |||
| why extend option in disk management is gray? | Vista General | |||
| Computer Management --> Storage --> Disk Management | Vista account administration | |||
| Hard drive management - extend | Vista General | |||
